700r from a 6 cyl van???
Old Sep 30, 2000 | 01:28 AM
Metallica383's Avatar
Will a 700r from a 4.3 engine work on a V8 motor. I was just wondering my tranny went today and i need a replacement.
Old Sep 30, 2000 | 01:36 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
yep. will have to change tailshaft housing should be all to get it bolted in.
Old Sep 30, 2000 | 01:50 AM
Is it a good idea to replace the torque converter while replacing the tranny and will the converter work off from the 4.3?
Old Sep 30, 2000 | 06:54 PM
FastBroker's Avatar
Don't use that tranny!!! It has fewer clutch packs in it and it's valve body is calibrated to shift for a 6cyl. You will not be happy and you will break it. Call a trans shop and ask them, if you don't believe me.
Old Sep 30, 2000 | 08:30 PM
GOLD85's Avatar
ALL 700r4 have the same amount of cluth pacs.
my 700r4 came out of a 6 banger van, when i orders the rebuild kit i orderd it for a vette and got the same amont of clutch pacs, then i upgrade to 9 cluthc pacs. you are right about the valve body thought, but a shift kit can cure that
when the green flag drops the bull$hit stops
350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Old Sep 30, 2000 | 08:43 PM
So is the tranny any good will it hold out for a V8 or not I have some conflicts in the replies.
Thanks for the posts
Old Sep 30, 2000 | 09:27 PM
-=Nitro7=-'s Avatar
All I will say is this, when my 700 died not long ago I came across a good deal on a 700r4 from an Astro 4.3li, this tranny was a rebuilt one that a guy I know had at his shop. (Local tranny shop)when I advised him what I had intended on putting it in he talked me out of it saying I would be extrememly unpleased with it. I did buy another tranny from him a TH350 for a few hundred $$ less than the 700R4. So I do not know, but I would advise against it if at all possible.
Just my .02.
86 Camaro SC, 310, Edlebrock Intake and Carb, Flowtec Headers, Ported polished heads and intake. TH350 tranny, Jacobs Electronics Ignition.
Old Oct 1, 2000 | 12:31 AM
zippy's Avatar
Engine: 5.3L
going to be pretty much same internally. only a few differences. i didn't see you ask for opinions on this which is why i didn't give it initially. if you need one and it's available, go for it.
gta892000
Aug 11, 2019 11:16 AM
bjpotter
Oct 4, 2015 07:48 PM
kx3g
Sep 28, 2015 08:14 AM
armybyrd
Sep 15, 2015 06:06 PM
Saxondale
Sep 14, 2015 06:37 AM
