Is the LT4 production cam a good choice for my heads and header combo?
Old Mar 6, 2001 | 12:22 AM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
i am planning on using S/R torquer heads and edelbrock headers. at 140$ this cam is a steal...what do u think? if not do u have a recomendation on a cam? it is a daily driver and has to be Ct.emmisions and if possible not deminish my mialage.15in the city 21 highway
white/gold leather 5.7TPI 700r4 3:27posi twin cats aluminum d.shaft ported plennum,afpr,8mmwires,k&Nand all other "free" mods
Old Mar 6, 2001 | 12:07 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
ZZ4 cam from www.sdpc2000.com , its $100. And your heads should already have the right springs to handle the lift.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 7, 2001 | 10:36 AM
Beefy89's Avatar
You should be able to pass emissions with either cam.Your engine looks like it's more suited for the ZZ4 cam,but the LT4 cam will probably get better milage.I get about 14 to 15 mpg with my ported L98 heads and LT1 cam.
We need Perry Mason
Old Mar 7, 2001 | 06:33 PM
camaro6spd's Avatar
If i use (L98 engine)The GM High Performance Cast Iron Head 64cc(large Valve, 12480092),the Hooker Compatition exhaust, Flowmaster Cat-back, and freemods, which cam is better LT-1 or ZZ4, i am looking for an engine with torque and still some revs up to around 5500.
-Tom
Old Mar 7, 2001 | 09:29 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
what r the specs for the ZZ4 cam??
thanks
Old Mar 8, 2001 | 11:30 AM
Beefy89's Avatar
ZZ4 camshaft part#10185071 .474/.510 lift 208/221 duration @.05 112 lobe seperation.LT4 production cam part#12551142 .476/.479 lift 203/210 duration@.05 115 lobe seperation.
We need Perry Mason
Old Mar 8, 2001 | 11:33 AM
Beefy89's Avatar
The LT4 cam specs are with 1.6 rockers.
Old Mar 8, 2001 | 04:45 PM
Mike92's Avatar
So I should be able to use the stock springs with a ZZ4 cam on my Torquer 305 Heads then. They both have the same 1.25" springs with 7' Chromoley retainers.
Old Mar 8, 2001 | 04:55 PM
Kevin91Z's Avatar
Use the springs that came with your Torquer heads, yes. Do you know what lift they support? Might want to check that out.
Definitely get the ZZ4 cam over the LT4 regular cam.
Old Mar 8, 2001 | 07:10 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
according to WP they r supposed to handle up to .600 lift.what kinda power increase should i expext as far as HP and et. estimates. if u wanna give it a wirl will that extra duration from the zz4 compared to the LT4 make a whole lot of diffrence as far as driveability emisions and mialage?
Old Mar 8, 2001 | 07:17 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
i looked it up in sdpc by part# and it came up 193$ hmmm
Old Mar 9, 2001 | 03:15 AM
Kevin91Z's Avatar
SDPC was selling the ZZ4 cam for $100, they must have stopped that sale.
Yes I still think the ZZ4 cam is worth it over the LT4 cam. The LT4 cam is basically a stock cam, and not much better than the L98 cam you have now. Since you're getting the higher flowing heads, get the better cam to go with them.
Old Mar 9, 2001 | 07:23 AM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
The production LT4 is a bit milder than the ZZ4, but if you want just a little bit over the ZZ4, the LT4 HOT cam may be what you are looking for.
I want to get a set of AFR fastburns and the LT4 hot cam to replace my "stock" ZZ4 heads and cam.
Of course I have to convince my wife that I really need them - she is already bitchin about the new accel intake and runners that I "need" to have.
Production LT4 cam:
I: 203 E: 210
I: .476" E: .480"
LT4 Hot Cam
I: 218 E: 228
I: .525" E: .525"
ZZ4
I: 208° E: .221°
I: .474" E: .510"E
89 Firebird Formula
WS6 package,ZZ4 Crate engine
SLP 58MM TB, Edelbrock TES Headers
Random Tech 3" cat, SLP 3" stainless exhaust
9 bolt rear, Hotchiss swing arms, Lakewood panhard rod
Corvette 2/4 servo, kevlar band, full poly rear.
Centerline 16x8 rims, B.F Goodrich drag radials
Old Mar 9, 2001 | 02:09 PM
Kevin91Z's Avatar
Dont forget the lift on the LT4 cams (both of them) is shown with 1.6 rockers, while the ZZ4 cam is 1.5 rockers.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro71633
Sep 1, 2015 10:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
TreDeClaw
Aug 14, 2015 06:58 PM
anesthes
Aug 8, 2015 09:37 PM
