Ideas on engine pinging
Old May 30, 2004 | 08:22 PM
pigsticker's Avatar
Car: 1992 z28
Engine: Vortec 350 TPI
Anyone got any ideas on how to make an engine stop pinging besides running the high octane gas in it. The computer has been by-passed and so the knock sensor doesn't work anymore. It's not terrible, but none the less annoying.
Old May 30, 2004 | 08:42 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
What kind of engine/induction?
Old May 30, 2004 | 08:43 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Is it pinging because something is wrong with it or just becuase the compression ratio is too high for the fuel U use?
Old May 30, 2004 | 09:19 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I need to know engine/induction as stated above, but offhand, I'd say the timing could be too far advanced, or it's too lean of a mixture. Just a quick side note, when an engine pings, it's like hitting everying in the combustion chamber and rotating assy. with a hammer, and pinging starts way before it's audible it only becomes audible when the valves start getting slamed shut, and the piston starts getting slamed aganst the cylender walls.
Old May 30, 2004 | 09:24 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Watch out because your engine will be destroyed.
Old May 30, 2004 | 10:40 PM
pigsticker's Avatar
Car: 1992 z28
It's a 305 with an Edelbrock intake and Edelbrock 650 carb and headers. Other than that, it's stock.
Old May 30, 2004 | 10:43 PM
pigsticker's Avatar
Car: 1992 z28
I doubt the compression is too high because it's stock besides the intake, carb and headers. The only thing wrong with it is the engine is not using the computer to work. The computer has been by-passed.
Old May 30, 2004 | 10:58 PM
Engine: 383
do you have the stock eletrical distributor or a old/aftremarken vacume distributor...if you have the stock one it WILL NOT WORK without the stock carb and the coumputer, also what is your timing set at and how do your plugs look?
Old May 31, 2004 | 08:02 AM
thirdgen88's Avatar
Car: 1995 Corvette
Yeah, you need to use a '74-'79 GM HEI with mechanical and vacuum advance (well, this would be an easy one to use, there are of course other options)..
Old May 31, 2004 | 09:23 AM
Vader's Avatar
Or, you can bolt your old E4ME (780 SCFM) back on the Edelbrock intake and re-enable all the ECM functionality.
Old May 31, 2004 | 11:40 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
E4ME (780 SCFM)
This may be a stupid question but what does the "S" stand for? "S" cubic feet per minute.
Old Jun 1, 2004 | 06:20 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Prolly just a typo.
Azrael91966669
25
Jun 20, 2017 04:04 AM
NinjaNife
Aug 23, 2015 11:49 AM
perZ
Aug 15, 2015 01:17 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
