carbed L98
Car: 1985 camaro
Engine: mpfi 2.8 v6 hopefully soon to be 350
carbed L98
I looking at getting a '87 l98 w/ tpi but i want to go carb for my swap. can i just pull off the tpi unit slap a new intake manifold and a carb on or am i missing a lot of thing
thanks for any help
thanks for any help
Car: 1985 camaro
im looking at getting rid of the ecm completely cant i just run a non computer controlled carb or does the ecm control other functions i still need i also know im gonna need a new dist
Transmission: 4L80E/4L80E
The ECM controls the ignition timing and the torque converter clutch of an automatic transmission with such a feature.
It also controls some emissions equipment like A.I.R. and EGR, but I'm assuming since you're eliminating the ECM and going carb, that isn't something you're concerned with.
Car: 1985 camaro
im not concerned with emmisions really ill find a way around those but i do want it to run properly. so can i just get a msd ignition and then isnt there a $20 part for the convertor?
thanks for the help so far
The only "kit" I have seen lately was in the $160 range.
For a TH700, you can modify the 4th gear pressure switch so it locks the TC whenever you're in OD. That may be about a $20 mod.
Car: 1985 camaro
ok the trans will be a 700r4 and i swear a saw someone say summit sells something cheap to do that ill have to look into it
http://store.summitracing.com/partde...%204294925134%
There might be something else out there, that's all I could find on Summit or Jegs.
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Youll need a non cc distributor, carb, manifold, new throttle linkage, a mallory bypass style fuel pressure regulator, and some way of locking the converter. There is a tech article in the tech section of thirdgen.org there details everything. Good Luck.
