Engine rebuild qustion please help
Old Oct 11, 2004 | 06:25 PM
87camaro kid's Avatar
Car: 1987 Z28
everything on my rebuilt motor minis the intake manifold , spark plugs, and oil pan is all put to gether. I have eldebroke heads that where slightly milled for a little more compression and the motor was bored .06 over. My qustion is how hard should it be to turn the motor over using the crank tool and a ratchet? if the vibration damper is on should i be able to turn it by hand?
My second qustion is what on my 87 305 motor will fit on this 89 350 motor? mainly i wanna no if the water pump, crank pully, and oil filter housing, and the rest of the accesorys including the power stearing pump will fit on the 350
please help me out im trying to put the rest of the motor together so i can start the swap
Old Oct 11, 2004 | 07:23 PM
ljnowell's Avatar
This has been covered a thousand times.
Old Oct 11, 2004 | 08:22 PM
Car: 1987 Z28
iv searched and i cant find anything on it
Old Oct 11, 2004 | 08:47 PM
sellmanb's Avatar
Car: '86 Berlinetta
not sure about the water pump but everything else should be able to fit nice n snug.
Old Oct 11, 2004 | 11:42 PM
1320 Right Ln.'s Avatar
all the parts mentioned should fit. as far as turning over the motor, if you've got the entire short block assembled, then you should be able to turn the motor with a long handled ratchet with u're crank socket tool. The resistance should be very noticable, without the ratchet, you'll probably have a very hard time turning the motor with just your hands.
I wouldn't worry about how hard it is to turn over though. As long as you paid careful attention to proper clearances throughout the build, you'll have a happy, long-lasting engine.
Old Oct 12, 2004 | 03:36 PM
Car: 1987 Z28
im a little confused i no on 87 and older it is clockwise rotation and on 88 and newer it is counter clockwise rotation...if i use the accesorys from the 87 305 on the 89 350...if it fits...will i have to use the clockwise water pump then on the 89 350?
Old Oct 12, 2004 | 03:42 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The "rotation" is in reference to the water pump, both motors spin the same way.
The sepentine belt waterpumps are "reverse" rotation, not sure what you're '87 was setup like, but if you're swapping all '87 stuff onto the '89, no worries, everything will spin correctly.
Old Oct 12, 2004 | 04:18 PM
Car: 1987 Z28
so use the 87 water pump then?
Old Oct 12, 2004 | 04:26 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
yes
five7kid's Avatar
Transmission: 4L80E/4L80E
Yep.
Infested
May 22, 2018 11:56 PM
backtothe80s
Sep 5, 2015 12:39 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
hokis
Aug 9, 2015 03:57 PM
