Anybody Using Moroso 6qt Oil Pan?
Old Nov 14, 2004 | 10:13 AM
JesasaurusRex's Avatar
I have a Moroso 6qt pan for 82-92 camaro part # 710-20180
on summits web page it says that this oil pan will not clear a stroker (383). Well I think my crank shot on me and if it did i will really want to buy a 400 crank. Anybody using a 400 crank with this oil pan with any clearance problems? Please no smart asses that say it wont work just because summits web page says so. Would like to know from somebody with a 383 that is using or has tried it.
Old Nov 14, 2004 | 10:37 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
I have the pan on a 406 and it works great with no problems.
Old Nov 14, 2004 | 11:36 AM
awsome bro thx
Old Nov 14, 2004 | 05:23 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I had that same pan on my 400 and only had a slight rub on one of the counterweights. Not a big deal...just had to dent it a little with a hammer. Might wanna check for this when you do a dry assembly. I noticed mine after installing the pan and rotating the motor over by hand.
Old Nov 15, 2004 | 03:04 AM
Appreciate it guys thanks.
Old Nov 15, 2004 | 07:18 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Using that pan on my 383, no clearance problems.
Old Dec 9, 2004 | 09:10 PM
Spdfrk1990's Avatar
I guess ill be ok also cause i was about to order that pan what about timing covers which ones do you guys like. I was just gonna get this one but it says 95 and up i dunno not for lt1 or ls1. zz4 plastic #12562818
Old Dec 20, 2004 | 04:50 PM
Igor's Avatar
Engine: 383 carbed sb
Transmission: th350
i got it on my late model 350 block, using scat 9000 383 crank... no issues, had the same question as you before I built it....no solid answers. But when I put it on, no prob.
BDR
Nov 7, 2015 03:05 PM
project89
Sep 22, 2015 09:35 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
