Why Wont my car die when I shut it off???
Old Jul 16, 2001 | 10:09 PM
Metallica383's Avatar
After running my camaro which is carbed it is a daily driver that I picked up a while back just to mess with but it has always run good but it keeps wanting to run when I shut it off. What causes this and what can be done to correct it. As far as I know this car is a stock 305 carbed.
Old Jul 16, 2001 | 11:02 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
dang it, I just talked to a mechanic at work about this same question, and of course I forget the answer! Until then rev your engine slightly right before you turn it off, that will work, but I don't think its that great for the car.
late model 91 rs
fully loaded t-tops, red leather
paint- gm red and yellow blend (light red)
custom painted 16" Camaro rims
305 tbi 14"x3" O.E, computer chip, accel super stock plug wires
Edelbrock 3" cat-back
MTX sub and amp, Bose all around
vic_v8@yahoo.com
street kills: a lot of "family" cars, pickups, New v-6 stang, totally killed '86 SC Camaro.
Old Jul 16, 2001 | 11:35 PM
CMSII's Avatar
vacuum leak, if its an auto trans turn off the key while the trans is still in drive , but get it fixed quick, its running lean.
CMSII
Old Jul 16, 2001 | 11:52 PM
91z4me's Avatar
This is called deisling. My old s-10 did it. Just shut it off in drive if it happens all the time then get it checked out. but if it is every now and then don't worry about it
Old Jul 17, 2001 | 01:51 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Suggest you check base timing first. High combustion chambers temps (from vac leaks, or high coolant temps" can aid in "deiseling".
Fuel leaking from carb into the intake as well.
Set the timing to spec, check for vac leaks all over the vac lines, then maybe decarbonize the topend with GM Topend cleaner.
Old Jul 17, 2001 | 02:18 AM
CHVYPWR's Avatar
Car: 1978 El Camino SS
Transmission: T-5 & 3.73's
Somthing in the combustion chamber that is hot enough to ignite the left over fuel is causing the run-on. Could be red hot glowing piece of carbon, or an over heated exhuast valve. You are going to want to check the timing first. If the timing is correct, make a couple of WOT take offs and redline shifting to burn out the carbon. Also try a better grade/octane fuel.
Ya can't have too many fast Chevys!
Old Jul 17, 2001 | 07:54 AM
gravitar's Avatar
I used to have a dieseling problem on my cutlass. Although the best solution would probably be to pull the heads and scrape all the carbon out, I found that if you kill the ignition with the car in drive, it'll quit dieseling a lot sooner than if it were in park. Of course, this only applies to auto tranny cars
Old Jul 17, 2001 | 12:30 PM
89REDGTA's Avatar
You have too much carbon buildup in your combustion chambers. This is typical of high mileage carb engines. You could either shut the car off in drive or use premium fuel. Remember that higher octane fuel is not as volatile as lower octane fuel. This has worked for me with my 86.
Old Jul 17, 2001 | 01:17 PM
Chronos_Titan's Avatar
If you have to run a higher octane fuel and the engine is in good tune that engine is almost dead. If you can not tune the problem out you are going to have to pull the heads. Most cleaners do not work very well but you can try them if you want. I would start saving for a 350.
Wade787b
Sep 29, 2015 01:15 PM
djmarch
Aug 9, 2015 05:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
