Car was running, saw a spark then car shut down
Old Apr 19, 2005 | 07:58 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
Ok
Just a regular day changed the oil, then saw a gromet that had come off a hole. So i went to push it back on (the car was still running) as i did that i saw a spark from the teal blue circled area. Probably from the bottom left to the right of the arrow, around there. As soon as it sparked the car shut off. I was like holy **** what just happend. So i go ok, turn the car with a quick twist of the key to see if it would turn and it did so i didnt wait for it to start. Well when i was done the car wont start!.. it rotates but I dont think its getting gas. I checked all fuses under the dash.. I dont think the F/p is kicking in now. ANd uhh!! someone please help
Attached Thumbnails Car was running, saw a spark then car shut down-picture-082.jpg
Old Apr 19, 2005 | 08:02 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Make sure that the wires that passed through that hole in the firewall are not exposed. it the grommet fell off then the wires could have chaffed down past the insulation and shorted out your fuel pump relay.
Old Apr 19, 2005 | 08:11 PM
Car: 2002 SS
Engine: Ls1
It looks to be the speedo cable that goes threw that gromet. It came from one of those black box things at the bottom. had nothing to do with the wires going threw that gromet.
Old Apr 19, 2005 | 08:12 PM
Car: 2002 SS
Engine: Ls1
where's the relay at?
Old Apr 19, 2005 | 08:50 PM
Car: 2002 SS
Engine: Ls1
ok i found it, is there a relay i can substitute just for tommorrow? or no other one will fit or i could spare
Old Apr 20, 2005 | 07:51 AM
Car: 2002 SS
Engine: Ls1
changed the fuel pump relay, still no sound of the f/p.
Old Apr 20, 2005 | 08:44 AM
Car: 2002 SS
Engine: Ls1
I put 12v power to the link diagnostic and the f/p kicked on. So it has to be somewhere from the fuse to the relay.
Old Apr 20, 2005 | 03:09 PM
Car: 2002 SS
Engine: Ls1
please help meeeee
Old Apr 20, 2005 | 04:15 PM
Car: 2002 SS
Engine: Ls1
Trickster
"There is no fuse for the fuel pump under the dash, it is located in the engine bay near the battery. That is what sends power to the fuel pump relay."
Seen that in another thread. I thought F/P under the dash fuses meant fuel pump. Even in my haynes it had it under the dash.
Tricksters awsome!
Azrael91966669
25
Jun 20, 2017 04:04 AM
djmarch
Aug 9, 2015 05:27 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
