engine combo
Old Apr 20, 2005 | 03:26 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
engine combo
ok what do think this will make at flywheel
79' 350 (.030 over)
Vortec heads
1.5 rockers self aligning.
Edelbrock 650carb
Intake.....? take off zz4? need suggestions
comp cam xe262H .462I .469E Hydraulic flat
flat top pistons around 10 to 1..or so
cast crank....
Full exhaust
im still deciding on intake and exhaust. so any ideas would be nice. or even a different cam. but it cant be really expensive lol.
I also have some lt4 valve springs that i may put on so i could go with a bigger cam....not sure. i want a car that has decent vaccum at idle. thanx
Old Apr 20, 2005 | 06:45 PM
7plagues's Avatar
so my 1000hp guesstimate is pretty good?
Old Apr 20, 2005 | 06:47 PM
daverr's Avatar
350 hp is my guess
Old Apr 20, 2005 | 06:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Try a 750 CFM carb and an XE268 instead of an XE262, you'll still have lots of vacuum.
Old Apr 20, 2005 | 07:19 PM
7plagues's Avatar
so i guess i would be using the lt4 valve springs for that cam correct? anyone know how much it would cost to put those on my heads?
Old Apr 21, 2005 | 09:47 AM
7plagues's Avatar
so is this around $10,000,000 dollars to do? correct?!....
Old Apr 21, 2005 | 01:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The XE268 would probably work with stock springs, but I'd have to check to make sure.
Old Apr 22, 2005 | 09:36 AM
7plagues's Avatar
bump...
Azrael91966669
25
Jun 20, 2017 04:04 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
nuggie
Aug 25, 2015 01:27 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
