Solid roller lifter
Old Jun 6, 2005 | 11:36 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Transmission: TH350 3000stall
Solid roller lifter
What do yo think about comp cams splid roller lifter...They say that they where not desing to use on sustained idle,are they streetable,do i will get 50 000km from them?
Old Jun 7, 2005 | 12:19 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I would think that anything that couldn't be used on a sustained idle wouldn't be considered streetable.
Old Jun 7, 2005 | 09:52 AM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Re: Solid roller lifter
Apparently the lifters you have aren't the Endure-X lifters:
http://www.compcams.com/Technical/Cu...g/HTML/284.asp
I would try exchanging the ones you got for these, if you can.
Old Jun 7, 2005 | 12:25 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
The endurex where too expensive,If i use a small file i can probably make my own oil groove what do you think guys?
Old Jun 7, 2005 | 01:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://www.compcams.com/Technical/Cu...ML/368-389.asp look on p. 379
Old Jun 7, 2005 | 01:59 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Is there truth to the saying that solid roller lifters aren't designed for the street, and that it isn't 'if' the break, but 'when'? One of the gearheads here at work was saying that, and somethign about no matter how much lubrication they get, they always break at some point. He also said trying to put an oil groove on them wouldn't be a good idea.
Old Jun 7, 2005 | 02:04 PM
Car: '82 Trans Am
Transmission: TH475
It's doubtful weather you would be able to file it since it is more than likely hardened. You could use a dremel with a small cut-off wheel and cut some grooves in like the Endure-X lifters. Cut the groove at a similar angle - this helps to direct oil towards the critical inner axle/bearing area. Keep the groove depth and width small, so it doesn't bleed off too much oil pressure.
RB83L69, that tool is meant to increase lubrication for a flat tappet cam/lifters, and wouldn't help to lube the roller lifter's bearing.
Old Jun 7, 2005 | 03:01 PM
brutalform's Avatar
Smoktire, what is the profile of the cam you plan on using, and more importantly, what induction system, manifold etc.?
Old Jun 7, 2005 | 03:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The tool makes essentially the same groove as what you see on that lifter. Yes, it's not the greatest thing for oiling the bearings; but it's better than nothing.
Old Jun 7, 2005 | 03:37 PM
Car: '82 Trans Am
Transmission: TH475
Here's a good article on roller lifters:
http://www.iskycams.com/techtips.php#2008
Old Jun 7, 2005 | 11:55 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
I d'ont whant to mess with the lifter bore..Lifters are less expensive then the block.For the cam i got the extreme energy XR286R 248-254@.050"duration & i will use 1.6 rockers so the lift will be .614"-.620" lift match with the set of edelbrock victor jr pn:77599 with a super victor intake.This engine will see both street & strip.
Old Jun 8, 2005 | 02:54 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
don't leave any burrs!
Eric B
Old Jun 8, 2005 | 03:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I've bought entire running engines for less than the cost of a set of roller lifters.
Old Jun 9, 2005 | 08:34 AM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
380us $ ?
Old Jun 9, 2005 | 07:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Running junkyard engines are frequently less than $500 CDN, bare blocks are anywhere from $50 to $200 depending on condition, etc.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
KO1
16
Oct 15, 2015 05:00 PM
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
dusterbd
Sep 29, 2015 08:40 AM
