low oil pressure
Old Jul 29, 2005 | 08:29 PM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
low oil pressure
when i first start my car its at 30, then as i drive, it will slowly drop down to 10-0...what does this mean and what is usally a common cause of this?
Old Jul 30, 2005 | 12:54 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
you need to hook up a mechanicle gauge to check actual pressure. electronic gauges can lie...which is most likly the case. its pretty common for the sending units on our cars to misread or go out. mine has and i "have" 30 psi constantly, but i know my pressure is good from a mechanical gauge. there is a galley tap by the distributor, timing cover (somtimes) and by the sending unit. im 99.9% positive its your sending unit because at 10-0 psi like you said, you will definatly have bearing failure.
Old Jul 30, 2005 | 01:19 AM
Engine: V8 350 ci
"bearing failure"....well i do have a rattleing noise everyonce in a while........so should i take my car to a shop and ask to check my oip pressure?
Old Jul 30, 2005 | 01:46 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Most definately.
Failure to do so could cause engine seizure, or eventually a rod through the side of the block.
Old Jul 30, 2005 | 02:12 AM
Engine: V8 350 ci
Originally posted by R1UK
Most definately.
u think i got bad bearings? eh ill just take her to a shop n see wuts up
Old Jul 30, 2005 | 02:29 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
yes take her to the shop for a mechanical test gauge. the rattle could be anything, i doubt its a bearing. if it was a bearing begin spun, you would hear a knock, not a rattle.
Old Jul 30, 2005 | 08:40 AM
Engine: V8 350 ci
they is a knock when i step on the gas, but i already found ou t thats pinging
Old Jul 30, 2005 | 09:07 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
could you rephrase that..
Old Jul 30, 2005 | 09:11 AM
R1UK's Avatar
Engine: 302
Axle/Gears: 3:73:1
I think he means "pinking" ie pre-ignition as us old folks call it.
If you havent got a "rumble" ie main bearings, usually accompanied by a heavy knocking from the bottom end, still get it checked with a proper oil gauge.
If its a faulty gauge, not so bad, but if there is almost no oil pressure, its time to stop driving and get it fixed before its un-fixable.
Old Jul 31, 2005 | 08:50 AM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
You could try switching to a thicker oil, like 20w50 and see if the pressure still drops. If it does, I'd suspect the oil pump is gettin' tired. If the pressure stabilizes, i'd say your bearings are worn and need the thicker oil until you can replace them.
Old Jul 31, 2005 | 10:34 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
doesn't matter how thick your oil is, your bearings have to maintain approx. 3/1000 clearance. thicker oil does not replace that clearance if you go over it. i still say its your sending unit
Old Jul 31, 2005 | 12:08 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
keep it simple
start simple....get it tested with a mechanical gauge...report back on the findings...then we will go from there
Old Jul 31, 2005 | 12:16 PM
Engine: V8 350 ci
i will do it tomorroe (monday) get a test and let u guys know. thx guys for rhe help
Old Jul 31, 2005 | 12:28 PM
Car: 1989 Camaro
Main bearing clearance is 0.0005-0.0022 and rod bearing clearance is 0.0005-0.0026. As bearings approach the maximum limit, how do you think the mechanic takes up the slack? If you said "He uses a thicker motor oil", then you're a winner!!! You may now head to the next round of our questions. If you answered incorrectly, we're sorry to see you go, but wish you a happy day anyway!
Old Jul 31, 2005 | 03:01 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
where did you hear that? thats rediculous. .0001 won't barly even allow the hydrodynamic wedge around the bearing which is critical to friction bearing lubrication. 2/1000 yah, thats fine. what kind of mechanic are you dealing with, a greese monkey? taking out "slack" by changing to a thicker oil is rediculous, any "true" mechanic knows to do it right and put in new bearings.
Old Aug 1, 2005 | 02:44 PM
Car: 1989 Camaro
If you have a motors manual for your vehicle look it up. Otherwise, you can take it up with any car magazine who's ever declared the same or claimed to hear the same from a mechanic who built one of there motors. Just remember, don't shoot the messenger.
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
