I blew up my 350 guys...need some ideas and support!
Old Aug 25, 2005 | 01:32 AM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Well...here's the story about why my newly rebuilt 350 is on it's death bed.
About a week ago I (correctly) put a Edelbrock Performer RPM intake on my car with new gaskets and all. I've been driving it for a few days and realized I was leaking oil from the back of the intake. I checked the oil and it was a little low so i topped it off. Checked it yesterday and it was a little below full so I left it alone. Well.....
After I got of work at O'Reilly's tonite, I went to my freind's house to help him work on his '95 Camaro that he is putting a carbed 350 in. He just built his motor, and it is pretty much exactly like mine. Knowing that, we go decided to ahead and put his carb on my car to get it adjusted so he wouldn't have to worry about it during his "break-in".
Well most of us know that when you adjust a carburetor you are gonna have to rev it up, and your gonna take it down the road and "get on it" to see how the 4-barrels act and all. So we did and got it running real good. Well, on my way home I noticed that my oil pressure was reading lower than usual (about 35) and then it got worse (15) and I started to hear a knock. I made it home taking it real easy on her, and thats how she sits in my yard now. You can't hear the knock at idle, only when you hold it at about 1500 rpms or more...anyways-
I have two choices:
Rebuild it and bore it .030 over; turning the crank .010 and putting it back together.
-or-
Rebuild it and make it a 383 with this 400 crank that I have lying around.
Let me know your thoughts guys...
Matt
Old Aug 25, 2005 | 04:25 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
sounds like you spun a bearing,might be able to just polish the crank and replace the bearings?
a 383 will need different pistons,but if you get an internally balanced crank at least you could re use the balancer and flywheel/flexplate.
havent got my 383 running yet but i'm really close!if you do need to rebuild and can stand a bit worse mileage,go with the 383!
Eric B
Old Aug 25, 2005 | 04:56 AM
ede's Avatar
ede
how about option 3? figure out what the problem really is instead of guessing and go from there.
Old Aug 25, 2005 | 08:06 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
I agree, if it was a good engine otherwise, then find out first whats up, then look at fixing it.
It does sound like a bearing has spun, but thats not the end of the world.
Old Aug 25, 2005 | 09:57 AM
rjmcgee's Avatar
Loss of oil pressure isn't the proper time to limp a car home.
Old Aug 25, 2005 | 10:17 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Why wouldn't any one else think that it was a bad oil pump, the oil pump came loose and strated to suck the bottom of the pan or something like that?
Old Aug 25, 2005 | 10:24 AM
R1UK's Avatar
Engine: 302
Axle/Gears: 3:73:1
All depends on how good someones description of a noise is.
Old Aug 25, 2005 | 11:23 AM
ede's Avatar
ede
first thing i'd suspect is the sender, or gauge for low PSI readings
Old Aug 25, 2005 | 11:27 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Even if it was, you still need to figure out how much other damage was caused by the lack of lubrication.
Old Aug 25, 2005 | 02:27 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Not if the engine started to knock after low readings...
Old Aug 26, 2005 | 01:01 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Try taking off a valve cover and seeing if you get any oil at the rockers, that could check the pump, and gauge and other stuff at the same time. Wouldn't it?
Old Aug 26, 2005 | 02:39 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Screw the dead 350.
If you've got a 400 crank just laying around then buy ede's 400 block. It's for sale in his signature. Since everyone loves 350s, you should have no problem selling your bottom end to re-coup the loss.
NO REPLACEMENT FOR DISPLACEMENT!!
Old Aug 26, 2005 | 04:06 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: I blew up my 350 guys...need some ideas and support!
I have two choices:
-or-
Matt
So theres no oil in it? or there is oil?
-- Joe
Old Aug 26, 2005 | 07:40 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Eric B
he can use the 350 pistons with the shorter rods. that's how alot of guys used to make 383 sbc (sbc 400 crank and rods with 350 pistons) often it is called a poor mans 383 now. not worth to time and money given the price you can buy the right crank rods and pistons for now
I would tear into the 350 and see what happened
Old Aug 26, 2005 | 09:09 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
The first thing you need to do is diagnose the problem.The second is to find out why it happened.Unless you were brutal to it,it should not have grenaded from "getting on it".Something else is awry.If it's knocking,the chances of polishing the crank are pretty slim IMO.
I'm also a 400 fan,but I'd not mess with using a 400 crank for a 383 these days.There are too many high quality cranks out there for too cheap to grind down a stock crank and deal with all the balance issues,etc.
Bottom line,find out what went wrong,if it's a simple fix,there's no need to build an entirely different combo.But whatever the cause,learn from it.I honestly feel that if this is a fairly fresh engine,something wasn't right to begin with.
Old Aug 26, 2005 | 10:29 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: Re: I blew up my 350 guys...need some ideas and support!
-- Joe
Ya...would be the most reasonable thing to do on an oil leaking engine...
Old May 16, 2006 | 03:33 AM
Hey guys...I haven't been on here much lately, but I just wanted to say that this motor is still running....Changed the oil to 10-40 and I've been driving the car ever since...It still has a slight knock though.......oh well....maybe when I get some spare cash I will fix it good...lol
-Matt
Old May 16, 2006 | 12:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I drove an engine like that, about 10 years ago. It had been run low on oil and had a slight knock after oil was added (didn't belong to me at the time). Of course, it gave up at the worst possible time - when I was supposed to pick up my mother-in-law from the airport (no mother-in-law jokes here, she is a great lady and not one I would want to abandon anywhere, let alone at the airport).
Yours is going to do the same someday. The sooner you get it fixed, the better.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
IroczFan
Oct 6, 2015 10:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
theshackle
Aug 22, 2015 06:52 PM
Jlanz55
Aug 17, 2015 07:15 AM
