Braided line & fittings
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
I bought some SS braided line and some fittings to redo my fuel line. I was wondering how I attach the fittings to the braided line? No instructions were included and I dont want to mess anything up since this is my first time working with braided line and its a little pricey
Car: 83 Z-28
Engine: LG4
The hose goes into the red part but I think you are right about having to screw it down. I think I get how to do it now, loosen the red piece all the way, put the line in and then tighten it down. Just want to make sure. Here are the fittings if it makes a difference.
90 degree
straight
90 degree
straight
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The hose does go into the red end. The blue end attaches to one of these of the proper size:
The flared end would attach to the AN fitting, the straight side of the above fitting, which is NPT, would go into the caliper.
For the hardline to braided you need something like this:
The AN fitting, again, going on the flared side, the hardline (with the proper flare) goes on the other end with a tube nut.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check page 42: http://aeroquip.com/media/A-SPPE-MC0001-E.pdf
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by Lo-tec
From holley's site:
http://www.holley.com/data/TechServi...20Assembly.pdf
From holley's site:
Check the mark that you made on the hose in Step 2. If the hose has backed
more than about 1/16" out of the socket as you assembled it, curse and return
to Step 3.
to Step 3.
lol, even holley has a sense of humor sometimes.
ambainb
Apr 25, 2016 09:21 PM
