What are the symptoms of a starter not engauging, (everything tested o.k........)
Old Dec 11, 2001 | 08:22 PM
87 Camaro Z28's Avatar
Well, i finally finished the ignition switch, and that wasnt the cause of my car not starting. It seems to be in the same position as it was earlier now, as far as my car starting. O.k. heres the situation, i've used a new battery, got rid of the fuseable links in my starter wires, pulled the starter and had it tested and it came out good, tested my neutral safety switch came out good, replaced my ignition switch, and with all of this stuff done, when attempting to start the car it just does nothing, and the battery is good, full of charge. One thing i noticed, the temp gauge pegs when i crank it over. I have no clue what to check, but what are the possibilities that a few week old +battery cable go bad? I mean, could the heat from the exhaust manifold kill it? Could it just be a bad connection to the selenoid?
Otherwise stock Lg4
Mods: Intake, K&N filter, Flowmaster, Cat-pipe delete, MSD blaster coil, Open air element, ASCD Big block stinger hood.
Old Dec 11, 2001 | 08:27 PM
MONTYR1's Avatar
COuld be your Battery cables, CHeck your battery ground cable also, well does your lights work?
Old Dec 11, 2001 | 08:30 PM
rjmcgee's Avatar
try checking voltage at the starter while someone turns the ingnition for you
Old Dec 11, 2001 | 08:58 PM
yes, my lights work, and i also redid my grounds on the batter today, but still nothing. i'm gonna go head out to the parts store to buy another new + battery cable. This one is fairly new but it could be bad i guess. any other ideas? thanks
Old Dec 11, 2001 | 09:17 PM
rjmcgee's Avatar
use jumper cables to bypass your positive battery cable, this should tell you if the cable is bad or not
Old Dec 11, 2001 | 09:53 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Should have a starter relay located behind the driverside kickpanel...could be the cause.
Old Dec 21, 2001 | 11:14 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Does your 87 have a passkey? That same thing happened when I used a key without the passkey on it.
Old Dec 21, 2001 | 11:43 PM
MCMLXI's Avatar
My car has done this several times in the past, but all I had to do was to wait about 5 mins and it fired right up. It turned out to be that the stupid chip in my key was loose. I just used my other key and it never happened again. So basically did you try another key
Old Dec 22, 2001 | 04:22 AM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
87's don't have the pass key... try using a remote starter switch (aka screw driver) cross the poles on the starter and see what happens... post the results...
zroc
gta892000
Aug 11, 2019 11:16 AM
Grant2k
Apr 4, 2016 08:21 AM
BumpaD82
Feb 26, 2016 02:57 PM
sahlomonic
Sep 20, 2015 07:15 PM
Formula_88AE
Sep 3, 2015 01:47 PM
