Whining noise coming from the distributor?
Old Dec 12, 2005 | 11:11 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I think I have a whining noise coming from my distributor. Is this the noise they make just before they puke? If so, $100 seems to be the price for a reman from Autozone or similiar.
Old Dec 12, 2005 | 05:47 PM
jase's Avatar
Are you sure that it's coming there?If so it might very well be.How loud is it.
Old Dec 12, 2005 | 06:41 PM
Car: 91 RS
Engine: 350 TBI
Very loud. We can see some wear on the underside of the cap where the rotor is hitting it. We trimmed off part of the rotor to keep it from hitting, but it still does it. Now we think it might be the actual distributor assembly.
New cap and rotor = no fix.
Old Dec 12, 2005 | 06:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Maybe pull it out and inspect it to see if it could be fixed before buying a new one.
Old Dec 12, 2005 | 06:44 PM
Car: 91 RS
Engine: 350 TBI
I wouldn't know how to fix a distributor beyond a module, cap or rotor replacement.
Old Dec 12, 2005 | 06:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's not much to them. Drive out the roll pin, take the gear off and pull the shaft out.
Old Dec 12, 2005 | 06:57 PM
Car: 91 RS
Engine: 350 TBI
Can you buy the individual pieces beyond the gear and stuff already metioned? I think the dizzy is the root of it.
Old Dec 12, 2005 | 07:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'm not sure what parts are available new, I usually just mix and match parts from used ones.
Old Dec 14, 2005 | 08:13 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If needed, Autozone has Accell dizzy BRAND NEW for $127 (assuming you need non comp controlled vac advance HEI dizzy). I haven't checked to see where you stand lately on the mods - maybe you need something different. Ahhh, didn't know you were being "watched" did ya Gunny? LOL
It's the one with the brown cap, and comes with cap and nick knacks (springs and such - things I'm too stupid to touch). But they don't always think to show it too you when you ask for just a dizzy, often they just look up numbers in system for reman. parts on shelves in back rather than sell the new stuff off the drool rack.
The dizzy in my 1990 TBI "squeals" when it's cold (like now, under 40) in the morning for about 2 minutes, and has done it for 2 years now, but it all works ok - I took it all apart 2 years ago, put in new grease, rotor, and ignition module, and it still squeals when cold, so I left it alone and it functions, just noisily during the winter starts.
Old Dec 14, 2005 | 09:55 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
You may just need to shim the gear some more.
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
pimp2303
Jul 27, 2017 02:03 PM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
