? on removing a/c pully from v-belt set-up...
Old May 14, 2006 | 04:33 PM
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
so i got everything else off and now it is time for the pully. i'm kind of leery about taking it off because i don't want it to come crashing down...any advice on what to unbolt first and how to do it...
Old May 14, 2006 | 05:03 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Maybe its just me but that didnt make much sense...
Are you taking the pulley off the pump or taking the whole pump out of the car?
Old May 14, 2006 | 05:05 PM
Trah84Z's Avatar
Engine: 305 V8
sorry about that...i'm taking the whole pump out of the car...
Old May 14, 2006 | 05:45 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
then why not just remove the pump by removing the 2 bolts that hold it on to bracket... and slide it off.. really not that hard to do lol. after you get done doing that then remove the bracket.
Old May 14, 2006 | 07:38 PM
Trah84Z's Avatar
Engine: 305 V8
alright...i got the pully and the pump out and the one bracket that is on top of it. but then i tried taking off one of the little brackets that is attatched to the front of the engine block. the rear bolt came off fine, but when i went to take the bolt off that was furthest front, coolant came out of it and i promptly bolted it back up...what is up with this? it looks like a tiny bracket off the block that the other bracket attatches to.
Old May 14, 2006 | 09:02 PM
if i remember right. on mine your had the top bracket. the bottom part of the bracket it used to hold on the power steering pump and also bolts into the water pump i think.. I will need to go out and look in the morning. But i do distinctly remember that i could only remove the top bracket and had to leave the other one alone.
Old May 14, 2006 | 09:11 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
haha, my power steering pump bolt will do the same thing. It just goes right through into the water jacket. no biggie, just make sure you plug up the hole after!
You may also find a bolt on the lower passenger side front that will do similar except it leads to an oil galley and will spray oil!
Old May 14, 2006 | 09:16 PM
Trah84Z's Avatar
Engine: 305 V8
alright...i think i'll just leave those alone then...thanks for all the help...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Ironhead38
Sep 7, 2015 02:26 PM
85Special
Sep 3, 2015 04:21 PM
