water pump heater hose block off
Old Oct 23, 2006 | 08:05 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
has anybody blocked of the heater hose going to the manifold and to the water pump? i dont have heater core or anything and wanna take off hoses anybody know how thanks
Old Oct 23, 2006 | 08:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
If you don't have a heater core, you should be able to just bypass it. So rather than the hose going from water pump to heater core, then back to manifold, just go from water pump to manifold. It'd be like a 6" hose.
I've seen that a few times on pictures of big blocks.
Old Oct 23, 2006 | 08:23 PM
Engine: 355
that wont hurt anythinggoin from the water pump to manifold?
Old Oct 23, 2006 | 09:46 PM
Engine: 355
also by doing that would it cause to much pressure or cooling problem shorting the hose from water pump to manifold? dont wanna blow engine lol... anybody?
Old Oct 24, 2006 | 10:30 AM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
I've had that done for quite some time now, longer than 6" though. I use a piece closer to 36" long to give room for expansion.
Old Oct 24, 2006 | 12:21 PM
Engine: 355
so if i do longer piece from pump to manifold it wont hurt anything?
Old Oct 24, 2006 | 12:34 PM
Engine: 355
anybody?
Old Oct 24, 2006 | 01:03 PM
Blocking them off is better.
The hole on the WP is cold water (pump suction side), and the port on the manifold is hot water. Running a piece of hose between those 2 places essentially "short-circuits" the radiator. Hot water will simply pump out the top of the manifold, and get sucked right back into the WP without passing through the radiator and being cooled.
Use brass pipe plugs, not hose.
Big blocks have a different situation; they come with a factory-installed bypass (which incidentally alot of people block off). Doesn't apply to SBs.
Old Oct 24, 2006 | 01:22 PM
Engine: 355
do u by chance know the size plugs ill need? manifold and waterpump?
Old Oct 24, 2006 | 01:33 PM
Yes
Old Oct 24, 2006 | 04:53 PM
Engine: 355
k could u tellme the sizesplease
Old Oct 24, 2006 | 04:54 PM
Sonix's Avatar
Car: 1982 Trans-Am
It's like 3/8" NPT. You probably have a NPT-hose fitting on it now, rip it off and bring it to the parts store and size it up. You should be able to eyeball it though.
Old Oct 24, 2006 | 05:07 PM
Sorry about that; I kind of ran out of time right then.
It's actually ½" pipe.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
MoJoe
Sep 24, 2015 09:12 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
