carb cfm vs efi cfm
Old Feb 6, 2007 | 12:42 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
carb cfm vs efi cfm
Can comeone explain to me why comparable motors could run with an efi stealth ram that flows 275cfm, however you would need a 650 cfm carburetor on the same motor?
Why are the cfm numbers so different.
Old Feb 6, 2007 | 01:13 PM
grumpyvette's Avatar
275 cfm ratings on the stealth ram ARE FOR EACH INTAKE RUNNER
a CARB feeds all 8 RUNNERS
your ENGINE only pulls from one cylinder at a time but you need to supply enought for about two to three cylinders in the plenum,to not be restrictive
Old Feb 6, 2007 | 01:23 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
wow all i have to say is durh, i knew well enough the 275 cfm is at the intake base, i feel kinda stupid now
thanks!
okay new question
what is the most intake base cfm that can be supported by a stock 48mm tb without causing a restriction
Old Feb 6, 2007 | 01:51 PM
stock 48mm approximately 650cfm
52mm approximately 780cfm
58mm approximately 950cfm
oval blade mono approximately 1150cfm
that of course ASSUMES the plenum and MAF allow the full flow which they won,t in most cases
keep in mind your never going to run into a restriction in the throttle body untill the
intake manifold flow, heads flow , cam lift and durration,and exhaust are significantly upgraded, and that will require drive train changes like a high stall converter and 3.73:1 rear gear and higher compression ratio in the engine
another factor most guys don,t understand...
flow is rated at 1.5 inches, increase the depression and the flow jumps, thats why a stock TPI throttle body can feed a 454 big block, that tb that flows in the mid 600cfm can flow 800 cfm with a bigger engine and cam putting a larger drop on pressure in the plenum
http://users.erols.com/srweiss/calcdchg.htm
http://users.erols.com/srweiss/calcafhp.htm
Old Feb 6, 2007 | 02:05 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Intakes and cylinder head ports are flow tested at a 28" pressure drop.
Carburators (4bbl) are rated and flowed at a much lower pressure drop 1.5" very different.
2bbls are flowed at 3"
EFI throttle bodies are rated the same as 4bbl carbs 1.5"
So.... a 750cfm carb when flowed at the cylinder head port standard of 28" will flow 3240cfm.
Old Feb 6, 2007 | 02:24 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
okay so im going to need a little help putting all of that together
grumpy check the sig, its a speed density motor with stock tb, stealth ram intake, dart iron eagle 180cc heads, and a .50 224/230 cam. so its got some mods.
I have an LT1 BBK 52mm tb that i need to figure out how to convert to work with my tpi setup, have been told i just need to bore out one sensor hole or something to the like. Just hoping im gonna pick up at least 10 hp with it, but i know my heads are the biggest restriction right now
Old Feb 7, 2007 | 09:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
This is partially correct, what is left out is that the heads & intake at 28" is of water. It is a pressure drop of 28" H2O.
Throttle bodies and carbs are measured at pressure drops in inches of mercury. So the 1.5" and 3" of drop is in inches of mercury.
Which brings us to the next part:
1 pound per square inch (psi) = 2.04 inches mercury (in Hg) = 27.7 inches water (in H2O)
Doing a little rounding 28" of water approximately equals 2" of mercury. That puts the 740 CFM 4bbl carb at 1.5" Hg at 866 CFM at 28" H2O.
NewCFM = OldCFM * sqrt(2.0 / 1.5)
RBob.
Old Feb 7, 2007 | 03:47 PM
F-BIRD'88's Avatar
You're right. I stand corrected. thought wometing was fishy in my thinking. Couldn't remember if both were in of water or ??? Thanks
Old Feb 7, 2007 | 08:42 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
omg, how do you guys know/learn and understand this stuff, i am so lost lmao
you can be a total and complete grease monkey and have performed a billion engine trans and other swaps for over a decade and still not know what all this stuff means, such as myself for example
crazy stuff,
yall are gods imho, lol
nice thread here
Old Feb 7, 2007 | 08:48 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
agreed what i was really after that in my infinite genius i somehow missed until now
thats pretty much what i wanted to know, cause that gives you a good idea if your
gives what you need to compare whats going to hurt or help you in terms of a tb
Old Feb 8, 2007 | 09:59 AM
http://www.chevytalk.org/fusionbb/sh...hp?tid/131229/
this contains alot of useful info & links you might want to use
Old Feb 8, 2007 | 10:31 AM
Don't forget also, that the flow into an engine isn't a smooth, steady, constant thing; it's a series of peaks and valleys. Each cyl getting its gulp of air is a peak, which can be MUCH higher than the "steady state average" that you calculate from CID, RPM, & VE. The carb or TB must allow that PEAK in the flow, or else it will be a restriction.
The intake plenum helps average out the bumps in the flow. The smaller the intake plenum, the greater the difference between peak and average; and as a result, the GREATER the carb or TB CFM needs to be, compared to the "steady state" calculation. Which is why an engine with a giant single-plane intake needs a smaller carb than the same engine would, if it had a dual-plane with a small plenum.
Most port FI systems have a VERY LARGE plenum, and consequently, the flow through the TB is relatively smooth, and lacks any peaks that exceed the "steady state" value by too much.
The difference in head flow CFM numbers and carb CFM rating numbers, due to the the difference in the pressure measuring method, is less than 15%. Not a super huge discrepenacy.
PurelyPMD
May 5, 2016 04:57 PM
sreZ28
Oct 22, 2015 08:21 AM
customblackbird
Oct 1, 2015 04:30 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Scorched1984
Sep 15, 2015 03:42 PM
