Rear Main Seal
Old Mar 8, 2007 | 12:44 AM
dc_sniper9130's Avatar
Car: '84 Camaro SC
Engine: Swapping in a 305
Transmission: 700-R4
Axle/Gears: 3.23 One-Wheel Sqealer
Rear Main Seal
Hey guys,
I had a question about rear main seals. I'm buying some stuff from Summit that specifies a 2-piece seal, but do i really need to use a 2-piece with it? The parts in question are the crank and oil pan below.
http://store.summitracing.com/partdetail.asp?autofilter=1∂=SPE%2D4988&N=700+4294925024+4294908216+4294908198+4294925232+4294840045+4294881326+115&autoview=sku
http://store.summitracing.com/partde...w=1&N=700+150+
Logic would dictate that a 1-piece is easier to deal with, and the crank comes in a 1-piece version, but that oil pan doesn't, and I'd really like a finned aluminum one. Does the specification of the 1-piece or 2- piece really matter? If so, how much of an issue really is the maintenance of the 2-piece vs the 1 piece? Could someone please enlighten me?
Old Mar 8, 2007 | 05:37 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
the 2 piece pan wont work with a 1 piece RMS... 2 piece RMS have been around for a very long time they work and so do the 1 piece jobbers but a 2 piece seal is a little more tricky to get right if you havent done it before... and i believe that you can not use the 1 piece crank in a 2 piece block however they do make an adaptor to run a 2 piece crank in a one piece block
Old Mar 8, 2007 | 05:39 PM
Car: '84 Camaro SC
yeah, i have a 1970 block, which would be a 2-piece. this is my first motor build so forgive the slight case of retard.
-tony
Old Mar 8, 2007 | 05:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Your block will be 2 piece RMS if it was made before 1986, or 1 piece RMS if made after. All the other parts have to match the block.
Old Mar 8, 2007 | 05:42 PM
Car: 91 RS
Engine: 350 vortec
well what about me my engine was assembled in 94 but it still has a 2 piece RMS.
Old Mar 8, 2007 | 05:43 PM
Car: '84 Camaro SC
from the factory or rebuilt? if its a rebuilt you probably have a pre-86 block.
Old Mar 8, 2007 | 05:45 PM
Car: 91 RS
Engine: 350 vortec
nope straight from GM goodwrench
Old Mar 8, 2007 | 05:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
"Replacement" crate engines can still be had with a 2 piece main, most notably the "Hecho en Mexico".
Old Mar 8, 2007 | 06:34 PM
Car: 91 RS
Engine: 350 vortec
yeah just hope mexicans like turbo
Old Mar 8, 2007 | 07:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Well, the "Targetmaster" and "Goodwrench" replacement engines aren't exactly known for their outstanding build quality, so putting one on boost might be entertaining.
Old Mar 8, 2007 | 07:02 PM
Car: 91 RS
Engine: 350 vortec
well i dont care some say they are cheaply made others say there is no difference from the ones cast in the united states... most 4 bolt mains come from mexico
Old Mar 8, 2007 | 07:08 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I don't know if it's a question of the quality of the casting or the machining, they're just made as inexpensive low-performance replacement engines.
Old Mar 8, 2007 | 07:15 PM
Car: 91 RS
Engine: 350 vortec
well i got it free... do to some creative wheeling and dealing so if it cracks then it cracks.. but if it cracks it better crack right in 2 cause i will be pissed if its junk and doesnt look like it was fun
Old Mar 9, 2007 | 12:17 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
Thats how to live hahaha. Good luck with it.
Old Mar 9, 2007 | 12:26 AM
fbodyorbust's Avatar
no real imput here.....just that rear mains are a pain in the ***!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!............thats all......
xxx3man`
Sep 23, 2015 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
