spun cam bearing?
Old Jul 25, 2007 | 06:17 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
spun cam bearing?
Well, I installed a cam last week. Didn't have any problems til a couple of days ago, when I heard a light knocking noise. The noise seems to come from the front of timing cover at idle, but disappears with an increase in rpms. Also the noise is not constant, sometimes it makes the noise sometimes it doesn't. The oil pressure is normal though. Does this sound like a spun cam bearing?
Old Jul 25, 2007 | 06:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: spun cam bearing?
Cam bearings don't get "spun".
Old Jul 25, 2007 | 06:59 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
Actually i did have a customer that had one "spin" in a third gen chevy motor. (LSX or whatever) The only thing we could figure was that it seized or grabbed and twisted with the camshaft and wallowed out the journal. Made a complete mess out of the engine, he wound up going to the salvage yard and getting another entire different motor. but trust me you'll have MAJOR problems if that happens.
Old Jul 25, 2007 | 08:08 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
What kind of cam did you install? was it supposed to use a cam button? Please post some more info on the lead up to your problem.
Old Jul 25, 2007 | 08:13 PM
Sounds kind of like you're describing the sound that a fuel pump rod makes sometimes...
Old Jul 25, 2007 | 09:26 PM
Car: 91 Camaro RS
Lt1 cam into a l03 and I shortened the dowel pin. I only have an in tank fuel pump.
Old Jul 25, 2007 | 09:53 PM
What happens if you pry the timing cover toward the engine while it's running?
Old Jul 25, 2007 | 10:40 PM
Car: 91 Camaro RS
Haven't tried that yet, but I will in the morning.
Old Jul 26, 2007 | 09:13 AM
Car: 91 Camaro RS
I feel the knocking though the screwdriver. I guess I am going to have to tear into it just to see what it is.
Old Jul 26, 2007 | 09:50 AM
Does it get louder when you pry the TC inwards toward the motor?
Old Jul 27, 2007 | 11:21 PM
Car: 91 Camaro RS
Well, for some reason it stopped making the noise. I started it for a couple different trips and even had the motor get warm, but for some reason the noise disappeared. I won't be surprised if it started again though.
Old Jul 29, 2007 | 12:27 PM
Car: 91 Camaro RS
Either I was too tired and forgot to tighten the cam sprocket bolts or the bolts worked themselves out. However, it should be good now and I get to double check the cam timing.
anesthes
Mar 10, 2016 10:35 PM
angel2794
Sep 8, 2015 06:22 PM
z28guy134
Sep 1, 2015 11:50 PM
gixxer92
Sep 1, 2015 04:32 PM
anesthes
Aug 26, 2015 01:37 PM
