Car diesels before I turn it off, wideband shows 14.7 when idling...
Old May 23, 2008 | 07:32 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Ok so the car idles fine and drives OK. On the top end there is still a lean issue, but I am going to toss in bigger jets to see if that fixes it.
Anyways, I can idle in the driveway all the way till at operating temp. The wideband shows 14.7, or around there, and I shut the car off.... drumm drummbb bummm... Turns itself over a few times after.
Finally dies.
If I drive it for just a couple minutes, (cold). There is no problem.
The hotter it gets, the more turnover there is.
I had the problem in the past and the dyno shop said it was running lean, but the wideband showed OK then too. I am confused. please help.
Thanks.
-Dennis
Old May 23, 2008 | 11:51 AM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: Car diesels before I turn it off, wideband shows 14.7 when idling...
Timing can cause that too. It's worth trying.
Old May 23, 2008 | 12:15 PM
Engine: LS3
too much or too little?
If its doing that, it would seem to me that there is too much. But I dunno.
Anyone have any input on that issue?
Old May 23, 2008 | 12:17 PM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
Transmission: Built 700R4 w/ 2500 stall
Axle/Gears: 3:73 posi
is this a fresh engine or older one?
edit- never mind, looked at your pics and its new.
Old May 23, 2008 | 12:37 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Carbed engine right? 14.7:1 is chemically stoich yes, but in the real (racers) world, that's considered lean. Richen up your idle to 13:1 or so, and try that again.
It's almost like you have a vacuum leak now.
Old May 23, 2008 | 12:58 PM
Engine: LS3
Interesting that you say that, cuz some people think thats why the motor isn't making the power it should.
I will be testing that theory soon enough. I am getting a carb hat and plumbing it so that my friend can hook up a smoke machine to it, apparently it pump smoke into the intake at about 2 PSI, and whever you see it seep out, you have your leak.
I will def try to get this test done sooner rather than later...
Old May 23, 2008 | 10:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
?????? What?
Tune for 13:1 at idle
Tune for 12.5:1 at WOT
tune for 14.5 or so at cruise
Then drive it around for a few days and see if anything changes. It's a simple jetting change, and a few screw turns, shouldn't take you more than a few minutes.
Smoke machine? ugh, that sounds like a lot of *work*. If you think you have a vacuum leak, then grab a 1lb bottle of propane and move it around problematic areas while idling. You'll know when you find it.
I don't think you have a vacuum leak (unless it runs funny like it does?), I just think you've set up your engine to run too lean.
Old May 23, 2008 | 10:50 PM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
i dont know about the propane on small small leaks, ive tried it at work a few times on vehicals that had a small leak on intake gaskets, not anythign to cause a drivability issue, but enough to make the long term fuel trim go out of wack and it never did anything. Smoke is a good alternative to carb cleaner since it doesnt make a mess, but i agree with you, doesnt sound like a vacume leak to me.
Old May 24, 2008 | 10:18 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by dennisbernal91z
...Anyone have any input on that issue?
Common causes:
1. Compression ratio too high for fuel being used.
2. Throttle open too much at idle.
3. Timing retarded causing #2 to be necessary to maintain idle.
4. Crappy gas (can't say cheap anymore).
Or my favorite: #4 combined with #1 causing #3 to be necessary, which causes #2 to be necessary.
What is the cam, idle rpm and C/R of the engine, octane of fuel, and carb used?
A lean condition at idle would also cause it to diesel if it causes the idle rpm to be too high (vacuum leak).
Old May 24, 2008 | 07:14 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
where did u install the wideband sensor? if too close to the engine or to far it will be inaccurated
Old May 25, 2008 | 11:14 PM
discostu's Avatar
Taken from http://www.misterfixit.com/diesling.htm
The most common cause of that is the failure of the anti dieseling mechanism, sometimes an "anti dieseling solenoid", found on most late model carbureted cars. What is happening is that the throttle is remaining partially open when the engine is shut down, which gives the hot engine sufficient fuel to run without a spark from the spark plugs. Most hot engines have sufficient carbon build-up that remains glowing red hot and acts as an igniter for the fuel. The solution is to make sure that the throttle closes completely when you turn off the ignition switch. Check the throttle stop and make sure that the fast idle on the choke or the "bottom stop" isn't what is stopping the throttle from closing. It must be the anti-dieseling mechanism and that mechanism must be functional.
Old May 26, 2008 | 09:17 AM
Sonix's Avatar
Car: 1982 Trans-Am
Gee, how come I didn't think of that one eh? That's an obvious one eh? Call up holley and ask where the adjustment screw is on their anti dieseling mechanism....
I wonder if that's an AOL hotlink?
I don't think Dennis' engine is old enough to have any carbon buildup in the chambers, and I doubt his carb is sophistimicated enough to have an anti-dieseling solenoid.
Are your spark plugs the right heat range though? I think supervisors #2 and #3 is a pretty common combo there.
Old May 26, 2008 | 05:41 PM
Engine: LS3
I will double check the plug heat range. I know they are a bit hot, but can't remember.
I will also check to make sure the blades are shut all the way.
Old May 27, 2008 | 01:28 AM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
It sounds like your timing is too far advanced, which is causing the dieseling action. Everything being fine when the motors cold but dieseling when it's hot is a dead give away. Get a timing light and adjust the timing. Once you're within spec, drive it around and see if the problem goes away. If your idle gets rougher, do like sonix said and use the propane test to hunt down the offending vacuum leak.
Old May 27, 2008 | 02:58 PM
Engine: LS3
Will do next weekend! THX
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
