Toxik's Build
Old Mar 15, 2010 | 10:50 PM
  #201
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Toxik's Build
Links fixed, Venommotorsports is offline. First link.
Old Mar 23, 2010 | 10:58 AM
  #202
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Toxik's Build
So i've been thinking.....she needs more hp/tq ....this bug bite of speed isnt good for my wallet!
and yes im still saving for the paint.....( better performance sound soo much better) but then paint is good tooo.... ahhh so many things to choose from!
Old Mar 23, 2010 | 08:30 PM
  #203
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Toxik's Build
www.harrisspeedworks.com
Old Mar 24, 2010 | 01:09 AM
  #204
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
you know nitrous never crossed my mind......
btw you still sellin those c6 wheels? for some fatters one? btw i saw some bmw suv with 325 wtf! that was awsome!
Old Mar 24, 2010 | 12:38 PM
  #205
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: Toxik's Build
Steroids for cars.
Old Mar 25, 2010 | 08:12 AM
  #206
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
So.....what will shrink in the car if it goes on the roids.... heheh
Old Apr 4, 2010 | 04:59 PM
  #207
shankymank78's Avatar
Car: 1991 1LE 350
Engine: 383 12.1 comp afr 195, hsr,
Transmission: 700r4 by probuilt automatics
Axle/Gears: 1o bolt 3.55 motive gears
Re: Toxik's Build
iv got the same setup u don't need the tall valve covers as they will interfear with the alternator and the windshied wiper motor. im useing 36lb injectors and a ecm from arizona tpi. dont have the motor done yet but am getting close any suggetions or tips u have to help finish this project would be apprieciated. this install allmost is getting to the point were its not worth the trouble.
Old Apr 4, 2010 | 05:09 PM
  #208
Car: 1991 1LE 350
Re: Toxik's Build
u will have to use a throttle body from an 85 to 88 tpi camaro on the hsr intake. the one for an 89 to92 will not clear the fuel rail
Old Apr 4, 2010 | 05:25 PM
  #209
Car: 1991 1LE 350
Re: Toxik's Build
nice ride do you have any pictures of the completed install of the HSR intake ? im tring to put the same setup on my 91 1le could use some tips if you got any thanks. my email address isshankymank78@aol.com. i hope to hear from u. My email goes to my phone so it is easier to use that form of communication
Old Apr 5, 2010 | 06:27 AM
  #210
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
sry havt been to my comp in afew days,i have pics on my phone , pm me your number and ill send the pics thought text. just take your time man when your doing yours
my vavle cover did not interfear with anything, make sure you price everything out and then so you can know your budget , and then add a couple of hunder to it. for all the small things that you dont think about.
Old Apr 5, 2010 | 06:36 AM
  #211
Car: 1991 1LE 350
Re: Toxik's Build
Thanks for the advice I've blown my budget out of the water as I have around 9 grand into this engine now I'm going to go work on it some more today before work. I have pictures on my phone too. My number is 1207-975-9663 can't wait to c those pics
Old Apr 5, 2010 | 08:58 AM
  #212
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: Toxik's Build
I have Billet Specialties Tall Centerbolt Valve Covers which do not interfere with the windshield wiper motor, but did come in contact with the rear terminal tab on the STOCK alternator. I have purchased an MSD APS 160A One Wire Alternator which will just fit by the valve covers, as the rear terminal is a bit smaller and shorter than the stock size. But still just fits, I am thinking about trying to clock the alternator a different way since these alternators can be mounted in MANY different positions. Only thing is still getting the alternator bracing on the rear to work. Also is this really needed, I have no problem putting it back on, just wondering if it'd be okay without for a little while until I re-torque my header bolts after a nice drive.
Old Apr 5, 2010 | 01:18 PM
  #213
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Re: Toxik's Build
The bracing was implemented because the accessory brackets are made of poor quality metal and will twist and shear eventually after prolonged use. Whether or not this happens seems to be hit-or-miss. Some folks warp almost immediately, others never have a problem.
Old Apr 5, 2010 | 02:26 PM
  #214
Car: 1991 1LE 350
Re: Toxik's Build
You can use the aluminum brackets that came on all the gm v8 cars with a serpentine setup. That's what I have on mine. I believe some v6 cars used them too. And you can run it without ac or the smog pump you'll just have to run the belt Ia different way. If you wnt I could send u a picture of how I've got mine ill just need your phone number. I do all my work through my blackberry.
Old Apr 5, 2010 | 09:37 PM
  #215
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: Toxik's Build
Everyone and their phone pictures, you guys are funny. I am looking to find someone to make me a nice set of brackets like March Performance, with an idler to get rid of these ugly brackets and remove my ac and smog delete permanently. We'll see.
Old Aug 28, 2010 | 09:08 AM
  #216
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
so i blew my trans 2 days ago, or just the servos or somthing.... ughh so not cool anyways guess gona rebiuld it or t56 time? wich one?
Old Aug 30, 2010 | 09:16 PM
  #217
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
any ideas?
Old Aug 30, 2010 | 10:14 PM
  #218
Stephen's Avatar
Car: 87 GTA
Re: Toxik's Build
Go T56, because you know you wanted to & you'd regret spending the $ on the T5 if you did.
Old Aug 30, 2010 | 11:26 PM
  #219
Car: 1991 1LE 350
Re: Toxik's Build
Definitely go with the t56 much better trany. Hawks third generation sell the whole conversion kit for 2300 bucks can't go wrong with that. It way more fun to shift through the gears manually anyhow. Try to get the ones with the .50 sixth gear. You won't need to use it much around town but once you get on the highway it sure is nice to have. With stock 16 inch wheels,373 gears and the .50 overdrive your rpm at 60 will only be around 1400.
That what I'm doing after spending way to much to build my 700r4 I'm still not happy. Its got to go. Fourth gear in a 700 is .68
Old Sep 1, 2010 | 07:14 AM
  #220
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
wheels : 17x8.5 front 18x9.5 rear, love the six spds (t56's) had a 00' ta for too long ( got 11k for it,with 13k on the clock) anyways i've been debating weather or not i want to do this swap ( not scared of having to drill holes or **** ( if i screw up then ill just have to lear how to weld) b.c I will then have 3 vehicals that are all manual
00 jeep wrangler ( picking it up monday)
05 yamaha r6
and then the camaro.... you know what i think i might just do that ....
o heres another thing I will be doing to it. going to pull the motor out and give it a better bottom end ( forged blah blah blah) and some boost. but cant do all that till i find a steady job. wich will happen soon. but that my next project...screw paint
t56
build bottom end
rear end ( dont think a stock borg warner 9 bolt will handdle alll that hp/tq
mabe some boost too?
Old Sep 1, 2010 | 01:06 PM
  #221
Stephen's Avatar
Car: 87 GTA
Re: Toxik's Build
.......pull the motor out and give it a better bottom end ( forged blah blah blah) and some boost. but cant do all that till i find a steady job. wich will happen soon. but that my next project...screw paint
t56
build bottom end
So.....
Your gonna pull a fresh engine & rebuild the bottom end? Quit screwing around with your GenI engine & start a LS build, since that is what you want to do anyways.
Old Sep 2, 2010 | 11:11 PM
  #222
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
So.....
so is this you volenteering to buy all my gen 1 stuff so i can buy all LS stuff? you know you wana
Old Sep 2, 2010 | 11:13 PM
  #223
Stephen's Avatar
Car: 87 GTA
Re: Toxik's Build
If the price is right..... (like to see dyno # results)
Old Sep 9, 2010 | 10:38 AM
  #224
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
its gona be a slow build. but i will get some numbers after....uhhh soo much blahhh
Old Jun 2, 2011 | 03:25 PM
  #225
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
So in the next two week my car will be getting the trans done,just waiting on a buddy to use his trailer/truck.
My guy that was going to paint it,moved out to cali so paints going to wait.
I want to get some goodies for the camaro just don't know what to get? any advise?
Old Jun 2, 2011 | 03:29 PM
  #226
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
Re: Toxik's Build
roll cage?
Old Jun 2, 2011 | 03:48 PM
  #227
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
is it a good idea for a cage on a mostly street car? and don't really care about the back seat. but how many point cage is recomended? 6pt.8pt?
Old Jun 2, 2011 | 04:41 PM
  #228
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Toxik's Build
I'd go 6-pt with the Seat Saver bars. They even make rear Seat Sar bars for the hoop to hatch floor.
Old Jun 2, 2011 | 04:43 PM
  #229
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
Here is a list of thing i need to do /want
trans issue
front turn signals-
power antenna- have
tuning - running correctly with no issues
fix wiper system with sprayer
powerder coat weels black
rear spoiler- install fix firberglass tip, install led rear brake light strip and then pain
tune sound system
replace seats
carpet- $263.00 http://www.1aauto.com/1A/Carpets/Che...38/252858/1987
torque arm bushing- HAVE
weld on exter sfc peice -HAVE
put on fiberglass hood sturuts -HAVE
weather stripping -install (and have )
door actuators replaced ( have)
roll cage shoot around idea
momo-racing wheel
recplace oil drain plug with quick release - $26.95 http://www.quickoildrainvalve.com/Pr...ductCode=F101N what do you guys think of this?
fix leak in power steering pump.
key up lock cyclinder in fold down hatch cover
fix side veiw mirros
smoke rtail lights? mabe?
front steering upgrade $299 http://www.hawksthirdgenparts.com/ca...ebuildkit.aspx
fix heat/ac switch
upgrade guages and tripple gauge pod
wideband a/f guage- $250 http://cgi.ebay.com/ebaymotors/NGK-P...item588de38807
install plastics. a&b pillar- HAVE
headliners install- HAVE
rear veiw mirror swap- map lights leds- HAVE/NEED LED'S
69' nose emblem install -HAVE
fix amp mount-pain and cut out/carpet - HAVE
install mega shifter- HAVE
replace dash pad- HAVE
Old Jun 2, 2011 | 05:06 PM
  #230
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: Toxik's Build
design brake air ducts, line lock. idk just throwing stuff around. what does the 69' emblem look like?
Old Jun 2, 2011 | 05:53 PM
  #231
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
http://www.google.com/imgres?imgurl=...w=1262&bih=651
Old Jun 4, 2011 | 03:42 PM
  #232
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
bump about roll cages and line locks and other stuff ? help me out tgo!
Old Jun 15, 2011 | 03:28 PM
  #233
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Toxik's Build
I guess you dont need it but ifyou ever track it and run 11.49 or better its required. I dont use my back seats anymore and love the cage in the car. Makes me feel alot safer driving it. 6pt is fine. 8pt just adds 2 small legs to the rear main frame and ties into the trans tunnel
I got the competition engineering kit in my car. Bought the kit and my buddy installed it so there was alot of custom cutting and fitting but overall it was a decent kit.
Old Jun 15, 2011 | 04:02 PM
  #234
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
So I found this product called plasti-dip.... its like paint but comes off like latex gloves, and so the past two day when I had some time, I used the time to clean all the caked on brake dust off and started spraying them with some black paint. I did this rather than spending money to have them poweder coated, who know if I would even like pure black wheels too....I will post pics as soon as I get them back on my car.
I also have replaced my door lock actuators, charged my batteir and did alot of small things. I am making alot of progress and I will keep all you tgo-ers uptodate!
wont be able to do any work on the car this week end going to hyper-fest.com over the week end!!!! @ summit point raceway!
Their is more to update I just gotta finish my wheels while i still have daylight.
Old Jun 15, 2011 | 05:41 PM
  #235
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
Ok, I'm back with some pics of after paint.... the during/and before are on my phone and I don't know where the cord is.So in anyways here are my plasti-dipped wheels.
Old Jun 15, 2011 | 06:02 PM
  #236
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: Toxik's Build
now throw them on the car and lets see how it looks, i like the finish of the black
Old Jun 15, 2011 | 06:06 PM
  #237
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
me too i didnt spay two of the center caps I wanted to see how it would look with abit of polish on it. No I will not do the polished lip! im going to get food and beer ill post pics of em tomorow when they are dry on the car!
Old Jun 15, 2011 | 06:32 PM
  #238
Car: GTA
Re: Toxik's Build
No polished lip = they look like spare wheels, IMO
Old Jun 15, 2011 | 07:57 PM
  #239
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
well mabe I like the look of spare wheels i have some top secrect ideas that no one will see till i post up some pics after their done.......only a select few know.
Old Jun 16, 2011 | 10:22 PM
  #240
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
So I added some headlight fluid, but the cap got stuck so I used my left handed screw driver to pry it open. as soon as I filled it up this happend.....
she is floating!
are my wheels sticking out too far?
and black wheels!
Old Jun 16, 2011 | 10:32 PM
  #241
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
i know very bad picture but this is the other thought
then both my vehicles... I miss my r6
Old Jun 16, 2011 | 10:55 PM
  #242
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: Toxik's Build
you have conveted the camaro to hovercraft..............very innovative
Old Jun 16, 2011 | 11:07 PM
  #243
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
HELL yeh!
Old Jun 16, 2011 | 11:11 PM
  #244
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: Toxik's Build
haha, looks good, i think the chrome center sorta sticks out a tad, you should peel off the lip but not the spokes and throw it back n there just for ***** and giggles
Old Jun 16, 2011 | 11:26 PM
  #245
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
yeh ive been hearing that alot that a polished lip would look good. I like the pure black with the black centers too.
Old Jun 16, 2011 | 11:38 PM
  #246
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: Toxik's Build
im not saying it doesnt look good, but if it just peels off and you want to give it a try just mess around with it, put the polished lip and center, or vice versa.. not to sound like a teacher, but its always good to give other things a try just to see instead of poopooing them right off the bat, i dont mean that in a rude way i think its me being me curious more than anything. otherwise great job
Old Jun 16, 2011 | 11:56 PM
  #247
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
I don't mind playing around with it. I am working on some top secret stuff that only one other person know about. till then the rest of you cats dont get to know lol but you all wiil see pics...
Old Jun 17, 2011 | 12:08 AM
  #248
formulax4's Avatar
Car: 87 GTA
Engine: Two cracked out gerbils
Transmission: 700r with a probuilt automatics kit
Re: Toxik's Build
Great to see more from you on your ride.Love your work.
Old Jun 17, 2011 | 12:19 AM
  #249
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Toxik's Build
Thank you! I'm always exepting donations....it will make the build go quickers and you guys can see more pics faster too! and not wait super long for an update.
Old Aug 14, 2011 | 09:09 PM
  #250
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: Toxik's Build
any updates or final decisions on the rims?
