Strong gas smell
Old May 1, 2010 | 05:01 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Strong gas smell
I am getting a strong gas smell coming from the driver rear fender area, near the filler. It only happens when I have a 1/2 to full tank. The cap is good, there are no holes in the filler neck, and nothing spilling during filling or any other time. I am thinking maybe that the cheap white plastic valve under there may be faulty. If not, what else could it be? It may be causing the low milege also.
Thanks, Rich
Old May 1, 2010 | 09:42 PM
thedrewdotcom's Avatar
Car: 1986 IROC
Re: Strong gas smell
is it hard to put gas in?? or can you just set the gas pump on full bore and let her fly?
Old May 2, 2010 | 04:49 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Goes in no problem, as normal.
Old May 4, 2010 | 10:06 AM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
No body else has experianced this?
Old May 4, 2010 | 10:48 AM
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
just keep it under half tank......... no but check make sure the vent tube is not kinked, or clooged also that vavle mayjust be the culprit hit up a junkyard........
Old May 4, 2010 | 11:07 AM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Been keeping an eye out, but it's hard to find Camaros and Birds in junkyards around here.
Old May 4, 2010 | 02:54 PM
game1939's Avatar
Engine: 383
yeah same here, good luck and if i think of something else i let you know
Old May 4, 2010 | 05:50 PM
94VERTiGO's Avatar
Had the same problem. Turned out to be a cracked gas tank. Where the filler tube attached to the tank. Never leaked, couldn't even see wetness on the tank, but when it was parked in the garage overnight, the smell was terrible. Glad my garage didn't explode.
Old May 4, 2010 | 06:02 PM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
It might be leaking out from the top at the sealing ring did you do a fuel pump recently.
Old May 5, 2010 | 04:16 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
No, to my knowledge the pump is the origninal. I will have some time tomorrow to get a closer look at everything.
edit: Also, I will add that when it was tested for emissions it passed the gas cap test along with everything else.
Old May 5, 2010 | 04:19 PM
Twin_Turbo's Avatar
Filler neck leaking, cracked around factory solder joint. Had the same issue, smelled bad when tank was near full.
The problem
The fix
Old May 5, 2010 | 04:37 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
The problem
The fix
Did you have a lot of gas leaking? I have no leaking at all.
Old May 5, 2010 | 05:09 PM
Twin_Turbo's Avatar
No dripping, just a very bad gas smell and somewhat poor mileage. Never noticed drops on the floor.
Old May 6, 2010 | 11:56 PM
1987CamaroZ28's Avatar
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Axle/Gears: factory 9 bolt with 3.45 gears
What valve are you referring to? Is does it mount in-line near the gas tank on one of the vent hoses? I'm asking cuz i just got everything back together in my car and I don't have a valve hooked up to either of my vent lines. I think forgot about it or lost it! Please confirm..
Old May 7, 2010 | 04:07 AM
Twin_Turbo's Avatar
This valve, the white thing in this pic:
Old May 7, 2010 | 09:10 AM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Yes the white valve. Did you know that cheap little thing costs $40 with shipping from the dealer and gm parts web site?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
