Engine id number??
Old May 5, 2010 | 02:36 PM
tylerv350's Avatar
Car: 1982 z28/rs... haha
Engine: 305(now) 333(soon)
Transmission: 350 3-speed automatic
Axle/Gears: 3.45 limited slip 10 bolt
Engine id number??
i bought my z28 82 camaro used about three weeks ago. its a car that needs some tlc, and because i cant drive it yet(only 15) thats about all i can do for it. its got a 350 tranny on it and a small block 350. the problem; i have the engine id, but i cant trace it to anything? the id number that i pulled is K0721Z5H. i've got some info on it that i dug up, but i was wondering if anybody could help me out with it. let me know if you need pictures or anything. thanks a lot.
-tyler
Old May 5, 2010 | 02:43 PM
DeuceNC's Avatar
Re: Engine id number??
I didn't return any hits from it. Try calling a GM dealer, they should be able to run it. What exactly are you wanting to know about it?
Old May 5, 2010 | 03:01 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Your looking at the wrong stuff. Casting numbers dont start with letters.
Old May 5, 2010 | 03:09 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
If the motor is not original to the car the only way you can ID the block is to get the casting numbers off of it. They can be found along the back and front of the block.
Old May 5, 2010 | 07:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Recheck those last 3 digits. They should all be letters and are usually hard to see what they exactly are.
An F could be a B, E etc. Since they are stamped in, they might not be perfectly clear.
K = St. Catherines, Ontario engine plant
0721 = July 21
Z5H = ???
Closest thing I could find remotely close to Z5H is ZRB which is a 1989 350. Does it have 5.0L or 5.7L in a castings? Is it perimeter or center bolt valve covers? What side is the dipstick on? Is it one or 2 piece rear main seal?
That can all help pinpoint a year range it might be from. All the casting number can do is give you a basic year range the block was used in and if it's a 4" bore block used on the 350 and other engines or if it's a smaller 305 bore block.
Old May 5, 2010 | 08:38 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Here is the link to a long list of engines. The engine casting number that you need is located at the rear of the block, right where it meets flush with the tranny. Along the rim it should read "GM 5.7" or "GM 5.0" . Now opposite of the GM logo, you should see a group of 6 - 8 digit numbers. That is the Casting ID.
http://www.chevy-camaro.com/chevy-ca...es.asp?group=1
Old May 5, 2010 | 10:41 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The 2 or 3 letter code stamped on the block pad truely identifies what car the engine originally came out of , Hp , trans ,etc.
The one basic block casting may have been used for many setups.
The famous "010" block everybody wants was in hi perf Vettes and 180Hp trucks
Old May 5, 2010 | 10:48 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Z5H = ???
Closest thing I could find remotely close to Z5H is ZRB which is a 1989 350..
Recent Vette engines have 3 letter codes starting with Z
ZAA in '79 through to ZXD in '96
1984 examples (CE =Ca emissions )
ZFC: 350ci 205hp AT
ZFK: 350ci 205hp AT
ZFD: 350ci 205hp MT
ZFL: 350ci 205hp MT
ZFF: 350ci 205hp AT CE
ZFM: 350ci 205hp AT CE
ZFN: 350ci 205hp MT CE
ZFR: 350ci 205hp MT CE
ZFH: 350ci 205hp EX
ZFJ: 350 ci 205hp MT EX
Old May 8, 2010 | 09:28 AM
tylerv350's Avatar
0721 = July 21
Z5H = ???
im pretty sure thats it, i think i did misread it. thanks a lot, ive been trying to figure it out. pretty sure that its permiter valve covers, dipstick on the passenger side, and thats all i got on it right now until i can get under the car.
Old May 8, 2010 | 04:39 PM
The casting id number for the block is on top and to the rear. It's not on the bottom.
Old May 21, 2010 | 11:13 PM
tylerv350's Avatar
guys i still got nothing, even with zhb. this is gettin to be a pain. can anybody help me out any further? i just need to know what kind of engine is in my car haha
Old May 22, 2010 | 11:36 AM
AlkyIROC's Avatar
Car: 87 IROC L98
If you're that concerned about it, pull the head off and measure the bore and stroke.
Old May 22, 2010 | 01:00 PM
... Measure the diameter. If the measurement is 4 inches across, or 327. It's not that hard to get the casting off the top/back of the block. All you need is a flashlight, a dentist mirror (small mirror attached to a rod), and a bit of patience.
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
MY87LT
Aug 17, 2015 08:43 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
