What SBC came with a factory windage tray?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: What SBC came with a factory windage tray?
Vette L98 and LT1 for one
Is only a half tray that fits in the pan sump ; not full length like aftermarket
See
http://cgi.ebay.com/ebaymotors/84-85...Q5fAccessories
See
Car: 82 Z28
Transmission: T400
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I believe the Z/28 and most of the Corvette engines had the cheezy factory oil baffle. No other applications were expected to spin fast enough to be worth the extra 65 cents of sheet metal.
Car: 1988 Pontiac GTA
Engine: 5.7 w/SLP cold air intake
Axle/Gears: 9 Bolt 3.27 with PBR brake upgrade
My 1976 Corvette with the L48 did not have a windage tray. My take on it is that the HP versions of the small block engines generally had them. They do require different main cap bolts with the mounting studs so the cost may have been a shade more than $.65
. Trending Topics
Does a windage tray:
The early Z28s came with them, for whatever reason. This pan http://sdparts.com/details/gm-performance-parts/360450 with this tray http://sdparts.com/details/gm-performance-parts/3927136. There are better trays however; I have used both Milodon and Moroso ones in that pan.
Personally I think Apeiron's cost estimate is a little bit generous. I'd estimate less than $0.25 in today's dollars of incremental cost increase. But hey... look at the list above, and think about if YOU owned a company, would YOU spend $0.25, or ANY amount, on making your product, if it didn't accomplsih AT LEAST ONE of those things?
- Improve a car's gas mileage?
- Improve warranty claims rates?
- Increase sales?
- Increase service profits?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I don't even use one. Using a deep sump pan and keeping the oil level lower so there's still enough oil for the engine, the crank doesn't get anywhere near the oil in the pan.
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
I guess I should have posted this in the History Forum. I'm not looking to find one, I have a few in my garage, I just wanted a list of what GM put them on.
gta892000
Sep 16, 2015 12:37 AM
