timing problem
Old Jul 20, 2011 | 11:19 AM
cser 84 Z28's Avatar
Car: 2014 Silverado 1500
timing problem
my dad and i advanced the timing on my 84 z28 and now whenever i put it in drive or reverse it stalls. im not sure how much he advanced it because he did it by sound then checked it with the timing gun. i think he advanced it 16* from factory specs. the car has a all stock 305.
Old Jul 20, 2011 | 11:41 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
Re: timing problem
stock should be at 6 deg. BTDC. the timing should be set with the EST (electronic spark control) circuit disconnected.
Old Jul 20, 2011 | 11:54 AM
Re: timing problem
we advanced it because the car didnt have enough get up and go to even pass someone on the highway
Old Jul 20, 2011 | 12:17 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
Re: timing problem
sounds like a bad pick up coil or ICM to me. i had the same issue.
Old Jul 20, 2011 | 12:49 PM
Re: timing problem
i just got done giving it a full tune up (plugs, wires, cap, rotor etc.) and the car runs great and has alot more pep now that we advanced the timing. the only problem is when i put it in drive or reverse i need to immediately give the car gas of it stalls.
Old Jul 20, 2011 | 01:47 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
Re: timing problem
thats what i mean. the pick up coil and ICM have a tendency to go bad and you dont replace those for a tune up. those may cause the drivability issues your describing.
Old Jul 20, 2011 | 09:09 PM
Re: timing problem
how much would it be to replace those by chance?
Old Jul 21, 2011 | 01:17 AM
affliction1's Avatar
Car: 89 chevy camaro rs
Re: timing problem
okay you advanced the timing.are you running higher octane now?also what does it idle at in park?
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
