'86 l98 cam?
Old Jan 25, 2012 | 01:54 PM
kill4thril's Avatar
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
'86 l98 cam?
what type of cam did the l98 come with from 1986? i was reading about the engine and all it says is that in 87 they switched to a hydraulic roller so what cam was in the 86? was it a Mechanical Roller ?
Old Jan 25, 2012 | 02:32 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: '86 l98 cam?
There was no L98 in 86.... at least for F-bodies.
And that was the year they started switching over from hydraulic flat tappet camshafts to hydraulic roller tappet camshafts.
Old Jan 25, 2012 | 04:45 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: '86 l98 cam?
The f-bodies got a very small flat-tappet camshaft.
the non-roller blocks can be converted for a roller cam, but it's not the cheapest thing to do.
Old Jan 25, 2012 | 08:23 PM
Vader's Avatar
Re: '86 l98 cam?
Correct - No L98 in 1986. Also, they didn't START changing to rollers in 1986. All 1986 models with a few rare exceptions got the flat tappet "LA" cam. My '86 was built in late July in Van Nuys and has the "LA" cam (Lame-Azz).
It is rumored that a few rare '86 test mules got the '87 M.Y. design roller block, and some with the L98, but I've never actually seen one documented.
Old Jan 26, 2012 | 09:05 AM
Car: 1992 Camaro RS
Re: '86 l98 cam?
That's what I meant, I wasnt very clear though.
However... what about the Corvettes? When did they get roller cams?
Old Jan 26, 2012 | 12:34 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: '86 l98 cam?
According to records the vettes got the roller cams in 1987 as well.
Judging from previous experiences, it is possible that a few managed to get out there in late 1986 models, and of course any dealer-replacement engines (warranty stuff) would create some 1986 models with roller cam engines.
Only one way to know for sure what you've got!
Old Jan 26, 2012 | 08:38 PM
kill4thril's Avatar
Engine: 355ci
Re: '86 l98 cam?
yeah the junk yard by my house clames that the 86 camaro they have is a 350 tpi but i dont think it is the 8th vin is an f so what motor would that be?
Old Jan 26, 2012 | 08:42 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: '86 l98 cam?
Look on the driver-side rear of the block on the mounting flange for the transmission and it will say either 5.0 or 5.7
then you will know.
Old Jan 27, 2012 | 07:30 PM
Damon's Avatar
Re: '86 l98 cam?
If it's an 86 with a 350 TPI you likely have an engine transplant situation. They were all 305 (5.0L) engines except for maybe a few extremely rare ones you're never likely to find for sale at a junkyard.
Jorlain
Oct 8, 2015 01:57 AM
scottmoyer
Sep 7, 2015 07:06 PM
Strick1
Sep 4, 2015 07:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
z28guy134
Sep 1, 2015 11:50 PM
