Possible to change sparkplugs on 305 V8 without going underneath?
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Re: Possible to change sparkplugs on 305 V8 without going underneath?
no,be patient,use proper extensions,and don't fight it.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
It ain't worth the effort of fighting from above. You can reach like 3 easily from the top. Just get the rest from below.
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
get some car ramps.
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
I did them twice from the top.... Very painful... Then i found out there 250,000 times easier to do from the bottom. Yes, two hundred and fifty thousand.
Car: GTA
I do mine from the top. #2 and 4 are the toughest under the old style AIR pump and diverter valve/plumbing layout, but can be done. #6 & 8 are pretty easy with a plug socket and a hex wrench (there is a REASON for the flats on a plug socket).
I did them from the top about a month ago. 7 and 8 are the real PITA. Def possible just be patient. I found the hardest part was threading 7 and 8. I triple checked it. Also took the hood off for other work i was doing but it helped with the plugs too
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Park it on a curb and lay in the street.
Back in the 70s when they started sending men into space for long periods of time and they needed to write stuff, NASA invested several million $$$$ to develop a special ball-point pen that would write in any position. How cool!!
The Russians, faced with the same situation, sent a pencil.
Who was smarter?
Park the car on a curb.
Who was smarter?
Car: GTA
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
