Car stumbles and dies..
Old Apr 17, 2012 | 06:07 PM
Tijoz's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
So I have no idea what si wrong with the car, on hot days after driving for over half an hour or so the Tachomaeter will "flicker" and it feels like no gas is getting to the engine needless to say it dies and will start back up but will have the same issue again.. I have a 1990 305 TBI with all the following new: Fuel pump, Fuel Filter, Fuel injector filters, Distrubitor, Cap, Rotor, Wires, Plugs, Ignition Coil, MAP sensor, TPS, Vaccuum lines ( year old), I did the code reading and got codes 21,23,42 and 45, The only time the service engine light soon has popped on was during this issue, Any help would be greatly appreciated.
Old Apr 17, 2012 | 07:35 PM
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Re: Car stumbles and dies..
HAve you checked the purge valve , Its part of the vapor recovery system, its eather on the charcoal canister or in line from the canistor to the TB. Its something that can be checked with a vacuum punmp
Old Apr 17, 2012 | 07:39 PM
Tijoz's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
I'll go ahead and check that out real quick.
Old Apr 19, 2012 | 09:29 PM
Tijoz's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
I went ahead and ordered the check valve for the purge canister should be in tomorrow I am hoping this will cure the problem.
Old Apr 27, 2012 | 03:03 PM
Car: 1987 Trans Am
Engine: 355 tpi
Did you ever figure out what the problem was with your car.
Old Apr 27, 2012 | 11:48 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Old Apr 28, 2012 | 08:14 PM
Tijoz's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Well replaced the gas cap and purge valve, Just got the new EVAP canister filter today gonna go ahead and install it, I notice after driving I will unscrew the gas cap and can hear the gas tank expanding like it was building up too much pressure maybe breather is clogged? Not sure yet so gonna try to unplug it.
Old Apr 30, 2012 | 11:45 AM
Car: 1987 Trans Am
Engine: 355 tpi
Just remeber after you install the new purge valve and the cannister to adjust the TPS. other wise it wont run right.
Old May 5, 2012 | 11:36 PM
Tijoz's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Thanks for the tip, I decided to get a new gas cap while I was at it since the old one didnt want to screw on correctly anymore made a huge difference now just figuring out idling issues but hey thanks for all the help!
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
squiggy2
Aug 9, 2015 09:30 PM
