3.1 V6 Engine Replacement Problems
Old Dec 19, 2012 | 06:48 PM
EvaN329's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
I just got a 92 3.1L V6 Camaro RS last year when the engine went bad on me. I got another engine and have been doing the swap myself. Everything has been fine up until I hooked up the battery. The bolt that the lug attaches to on the alternator was loose and caused the insulation on the wire to burn up when I turned the key. I replaced the alternator and replaced the hot-wire to the battery (the alternator was bad). I charged the battery and turned the key and I heard the starter engage but the engine would not turn over. The battery then had a low charge and the starter would not make a sound although my dash and interior lights were on and my stereo worked. I got the battery checked and it was good and I charged it and then hooked it back up and when I turned the key the starter wouldn't even engage. I don't know what to do from here. Any help?????
Old Dec 19, 2012 | 07:00 PM
ex-x-fire's Avatar
Re: 3.1 V6 Engine Replacement Problems
Does the engine turn over w/ a breaker bar?
Remove the starter & have it tested.
Old Dec 19, 2012 | 07:08 PM
EvaN329's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
The engine does turn over, and I do know the starter is good because it's the same one I used previously when the connecting rod in my old engine went bad.
Old Dec 19, 2012 | 07:11 PM
ex-x-fire's Avatar
Make sure the starter is grounded good, the big wire should have 12v all the time, small wire(s) should have 12v only when cranking.
Do you think you need to shim the starter?
Old Dec 19, 2012 | 07:19 PM
EvaN329's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
My main concern is that the starter was engaging before and now all of the sudden it's not when I hooked the battery back up, although I will try shimming to see if that does the trick
Old Dec 20, 2012 | 07:23 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
VATs issue?
RBob.
Old Dec 11, 2015 | 09:29 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I do have a spare nose from an old starter that also got eaten by this thing almost 2 years ago but the holes haven't been opened up to the new bolts yet. A couple weeks ago, i had made some adjustments down there and the starter was at it's usual tricks. The pinion was jammed. I had to pull up on the tail of the starter to get it to release. So i put another shim in, right? No go there either.
What i was thinking of doing was cutting an inspection hole of sorts into the bell as well as trying your suggestion of using the spare nose. That way i could physically measure and see what is going on down there. The hole wouldn't be more than maybe an inch or so square.
Old Dec 11, 2015 | 08:58 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Now how in the bleep did my post in my thread end up here? Stupid phone... I suppose that's what I get for posting at work on downtime .
Anyways, OP, you should make sure you have power on the purple (possibly green?) wire at the starter (small lug) when the key is turned to CRANK. If not, check to see if the SECURITY light is on. If it is, you won't be able to do anything until you fix the VATS issue. If the light doesn't come on at all, you will need to find the VATS module under the dash and make sure you have power at the pink wire. Also locate the starter enable relay under the dash, which will have the fat yellow and fat green wires in it. Jump those wires together and try to engage the starter again. If the starter turns then, you have an issue with the VATS starter enable circuit.
Also, if the SECURITY light is on, you could crank the engine all day but until you can get the light to go out, there won't be any fuel injection.
Elephantismo
Feb 13, 2019 12:51 AM
cking99
Sep 22, 2015 11:33 AM
drt-rcr
Aug 27, 2001 06:57 AM
auxout
May 4, 2001 04:48 PM
Jiffy
Mar 28, 2001 10:02 PM
