fighting with a leaking oil pressure sensor...
Old Mar 30, 2014 | 08:37 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
I have been fighting this leak for about a month now. It is the one above the oil filter. The first sensor the threads were stripped out. Got a new one and tapped the threads on the block. Put it in and it leaked. Had to replace it due to it making the fuel pump run consistently. When I took it out the threads still looked really good. Got another new one. Put it in and got a total of 5 turns on it into the block. It is leaking pretty bad still. Ran it for 15 minutes and there is a pretty big oil puddle under the car. Should I tighten it up some more? About had enough with it and thinking of job welding a plug into it and just using a sender up by the distributor for oil pressure.
Any ideas??
Old Mar 31, 2014 | 11:11 AM
Re: fighting with a leaking oil pressure sensor...
bump
Old Mar 31, 2014 | 12:21 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You didn't mention it- but did you use any teflon tape on the threads?
Old Mar 31, 2014 | 05:01 PM
i put about 2-3 turns of the tape on it plus it came with the paste already on it
Old Apr 1, 2014 | 07:11 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Are you sure the threads in the block are OK? What about getting a brass adapter to go into the block, then putting the oil pressure sensor into the brass adapter? Then you could see where the leak was coming from, at the engine-to-adapter, or adapter-to-sensor.
Old Apr 1, 2014 | 10:24 AM
What size adapter would it need? It would have to be somewhat short. Not too much room there.
Old Apr 1, 2014 | 10:25 AM
Also, i used a tap for the block. It was a 1/4 X 18 npt tap.
Old Apr 1, 2014 | 11:52 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That's true that is pretty tight up there. Maybe a 90 degree adapter? I'm out of ideas...
Old Apr 1, 2014 | 07:06 PM
cheapest extension i could find was like 12 dollars shipped and it is 1.75 inches long. idk if there will be enough room for that down there. really thinking about just putting a plug in there and taking the black wire from that connection and put a one wire sensor up top
Prodigious
Oct 4, 2015 11:20 PM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
bamaboy0323
Aug 15, 2015 07:20 AM
