Crank no start
Crank no start
So I have an 89 Camaro v6 2.8l which was pasted down to me hasn't ran for a couple months. Tried to start is didn't start, so here's what I've done to the car so far changed the distributor, new spark plugs, new fuel filter and pump and bypassed the vats. So it cranks now but still no start, looked into it more and found out that the fuel injectors don't have a pulse. Need help.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Crank no start
How did you bypass the vats ?
One quick and dirty way to tell if it’s a passkey issue is pull the prom and see if it starts in limp home mode.
If you have a tach is it moving during cranking ?
Engine: Lb9
Transmission: M20
Re: Crank no start
That’s not a real bypass, you can have a prom burned or check the blue wire at the ecm I forget the PIN number at the ecm I believe you have a 1227302 ecm. There is a dark blue wire at the ecm it should have 2.5-5v key on if the passkey is working correctly.
Post 16 has the pinout for the 302 ecm. Vats is not shown so you would need to look for a blue wire in a cavity not listed.
https://www.thirdgen.org/forums/tran...n-vehicle.html
Engine: Lb9
Transmission: M20
Re: Crank no start
The starter enable relay can still work and the passkey module not give out a hz signal to the ecm. You might want to try my two suggestions to rule out the vats.
Engine: Lb9
Transmission: M20
Re: Crank no start
remove the prom from the ecm. If it fires up you know its a vats issue.
Test 2 look at the schematic on the link in post #4. look for a dark blue wire at the ecm. It will be in a cavity not listed on the schematic pinout. measure the voltage with the key on . if you see 2.5-5v to the ecm than vats is not the issue. It looks like there is only one wire for the tps at c12 & c13.
Re: Crank no start
So I checked the dark blue wires on the ecm and I got no voltage from it. Not sure what to do next, but I heard about the prom chip that they put in the ecm that disables the VATS would you know where I could get one of those?
Engine: Lb9
Transmission: M20
Re: Crank no start
I can program out the vats for you , send me a personal message.
Btw is the car automatic or manual transmission ?
Out of curiosity what pin is the vats signal on ?
To just verify your findings you can pull the prom and it should run but horribly.
Engine: Lb9
Transmission: M20
Re: Crank no start
Btw there is this device to that can send the vats signal to the ecm.
http://www.bakerelectronix.com/products_vats/
Engine: Lb9
Transmission: M20
Re: Crank no start
Hers a link to what a prom looks like
https://www.thirdgen.org/forums/dfi-...om-calpak.html
It’s the larger of the two chips in your ecm. The smaller chip stays in place and is called a calpak .
If you pull the prom look at the notch in its holder. This indicates the correction it goes into the ecm. The prom can only go in one way. You will notice the carrier has lager on it and they are two different sizes.
Engine: Lb9
Transmission: M20
Re: Crank no start
With the prom out do you have injector pulse ?
Have you tried ohming the injectors ?
A low resistance injector can shut off all injector pulse.
Engine: Lb9
Transmission: M20
Re: Crank no start
They should be in the 15.5-16.5 range. Try unplugging them all and see if you get injector pulse. If you do contact southbay fuel injectors for a good deal on injectors.
https://www.southbayfuelinjectors.co...s-gm-1985-1992
Engine: Lb9
Transmission: M20
Re: Crank no start
Each injector , you can contact southbay08 to reconfirm.
Engine: Lb9
Transmission: M20
Re: Crank no start
It means you have one bad injector, did you unplug them all and see if you have injector pulse with a noid light ?
Engine: Lb9
Transmission: M20
Re: Crank no start
With a test light or bolt ohm meter on volts dc and the key on see if the injector plug has power.
Check the fuse next to the battery to see if it has blown. It controls the fuel pump and ecm.
To see if the ecm is powered up you can check accessory power at pin a4 and bat power at b1 & c16 at the ecm.
If the check engine light comes on with the key on it should be powered up.
Engine: Lb9
Transmission: M20
Re: Crank no start
So now it’s down to bad icm in the distributor, or bad ecm. Or issue with the purple/white wire from the icm to pin b5. You would have to check continuity on the wire.
I think the vats would be bypassed and injector would fire with the prom out.
Engine: Lb9
Transmission: M20
Re: Crank no start
Use your prom and give this a try cheap enough
https://m.ebay.com/itm/1986-GM-Midsi...pe!81223!US!-1
Engine: Lb9
Transmission: M20
Re: Crank no start
This is alittle but more but the hnm prom is for a 2.8l manual transmission.
It would not have vats enabled in the programming
https://m.ebay.com/itm/89-92-CAMARO-...0AAOSw8A1aaQsh
Car: 1985 Camaro IROC-Z
Engine: 383 HSR Comp XFI280HR Profiler 195s
Axle/Gears: 3.73 Posi
Re: Crank no start
Is your fuel pump turning on after you start cranking? Maybe a wiring gremlin between the dizzy/ICM and ECM?
Engine: Lb9
Transmission: M20
Re: Crank no start
The vats just cuts injector pulse not power to the fuel pump.
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
Dom Scarpellino
Dec 18, 2017 08:51 PM
tippyjeep
Mar 10, 2012 09:14 AM
rbrooks
Mar 3, 2010 11:50 PM
Superblue87Formula
Aftermarket Product Review
Apr 25, 2001 02:39 PM
