89 Camaro tpi 5.7 Crank but no Start
Old Oct 10, 2018 | 10:17 PM
Gunreaper's Avatar
I bought an 89 camaro tpi 5.7. Started and ran fine when I bought it. The problem is it pretty much will start the first time but wont restart unless it sets for 5-30mins. I can literally start it and let it run for 10 secs kill it and it wont restart for a few.
I've replaced plugs, wires, rotor, icm, and ive bypassed the vats with proper resistor. I hear the fuel pump and fuel pump relay fine. I just put a fuel pressure guage on it and it is 42psi when it starts and 42psi when all it will do is crank.
Old Oct 11, 2018 | 06:03 AM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Re: 89 Camaro tpi 5.7 Crank but no Start
Check your resistance in each of the fuel injectors
check cold, then start and let run. Then check again. Bet you have at least two bad injectors if the originals.
Are they RP greenish gray ones?
Old Oct 11, 2018 | 06:36 AM
Gunreaper's Avatar
[QUOTE=Gunreaper;6256182]I bought an 89 camaro tpi 5.7. Started and ran fine when I bought it. The problem is it pretty much will start the first time but wont restart unless it sets for 5-30mins. I can literally start it and let it run for 10 secs kill it and it wont restart for a few.
I did that yesterday at lunch. The front 2 on driver side was 5.6 and 7.4. The back 2 were 12.4 and 17.2. The passenger side were all 17s except 1 was 12ish.
would that make it not start? I work at a Ford shop and our main mechanic didn't feel like injectors would make it not start.
when it wouldnt start we sprayed starting fluid in it and it ran. Took a couple sprays and car picked up and ran on own.
Old Oct 11, 2018 | 09:44 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Yea looks like you def have some bad injectors.
Old Oct 11, 2018 | 09:52 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
All need to be at least 12.5
Old Oct 11, 2018 | 10:53 AM
Gunreaper's Avatar
Will that make it not start? It always starts on the first try but as soon as I kill the car it wont restart till I wait a few
Old Oct 11, 2018 | 07:08 PM
PaulyC's Avatar
If you wan to make sure, get a noid light and see that you are getting an injector pulse when cranking. I also would think if the injectors were faulty and that is the sole cause of this then they would give you more consistent issues but crazy things happen all the time. If you don't see pulses on the the one you are testing, you can disconnect the rest of the injectors in that bank to make sure a bad one isn't pulling the rest of the bank down. If then you get pulsing you have at least one bad injector in which case just replace them all.
Old Oct 12, 2018 | 12:55 PM
Gunreaper's Avatar
Ok got a noid light. When I put it on the first injector first crank and start the light pulses. However when the car would only crank but not start the noid light pulsed but faintly. Idea?
Old Oct 12, 2018 | 07:09 PM
GeneralDisorder's Avatar
You need injectors. The faint light is because the alt isn't running and the starter draw is pulling the battery voltage down. Trust us - with those ohm readings it is an ABSOLUTE IRON CLAD GUARANTEE that you need injectors. The TPI system is well known for this - the RP injectors had problems with the insulation on the driver coils.
GD
Old Oct 12, 2018 | 07:27 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old Oct 12, 2018 | 08:21 PM
PaulyC's Avatar
When you are seeing a dim pulse disconnect the two low resistance injectors (and/or all injectors on that bank) you measured and see if it gets brighter again. Also agree with the others, they are measuring bad, replace them.
Old Oct 12, 2018 | 08:29 PM
Gunreaper's Avatar
Yeah I already have the bosch 3 with extra orings coming.
Old Oct 12, 2018 | 08:37 PM
Engine: Lb9
Transmission: M20
Southbay are the correct length and do not require duel o-rings.
Dom Scarpellino
Dec 18, 2017 08:51 PM
lvixentd
Jan 12, 2016 11:06 PM
rbrooks
Mar 3, 2010 11:50 PM
CamaroX84
Jan 12, 2001 07:30 PM
