Cool sounding starter?
Old Jan 22, 2020 | 11:34 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I have one of those gear reduction starters and it works great but my car sounds like a truck starting up. Was wondering what the thoughts are here on some options. The kind I recall that have a higher speed and a cool "whine" to them. Are they 24V? Opinions sought. Thinking of going back to a stock style starter- at least it doesn't sound like a truck.
Old Jan 23, 2020 | 07:02 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Cool sounding starter?
Never really considered how a starter 'sounds,' providing it has been installed correctly, but if it works all the time, regardless of how cold the weather, and it doesn't heat-soak, count your blessings.
Old Jan 23, 2020 | 08:21 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I mean, if the starter is currently working and you aren't experiencing any problems with it I'd leave it alone.
However, when it dies, if there are no warranties on it, just go to Autozone and get a LT1 starter. Its smaller than the hem starter, easily available, and fits perfect.
As far as sounding cool? Don't know where to go with that.
Old Jan 23, 2020 | 08:54 AM
OrangeBird's Avatar
Car: 1989 Firebird
Gotta agree here with Ironwill and Thirdgen89GTA , to me the only "uncool" sound a properly shimmed starter could possibly make would be the sound of it not starting the engine on command .
The starter works for what ? 2 or 3 seconds each time you drive the car ? Cool sounds notwithstanding I'll go with the first rule of mechanical devices ;
"If it ain't broke , don't eff with it !!!!"
Old Jan 23, 2020 | 08:55 AM
Engine: 350 TPI L98
Transmission: WC T5
I know I'm being picky. But damned if it doesn't sound like a UPS truck starting up.
Old Jan 23, 2020 | 09:05 AM
CKone's Avatar
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
I know what you’re talking about. It is definitely the high pitched whine from a gear reduction starter. Very familiar with it being around dirt track racing for many years. I too dig the sound it creates so consider yourself not alone. Alas, the sound of the car starting regardless of the symphony coming from the starter is always music to my ears
Old Jan 23, 2020 | 09:53 AM
Wait. Op. Do you like the sound, or dislike the sound?
the gear reduction starters increase the applied motor torque. Which is required for higher compression engines.
Old Jan 23, 2020 | 12:03 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
I think the gear reduction starter does sound cool.
Old Jan 23, 2020 | 02:04 PM
Drew's Avatar
https://www.thirdgen.org/forums/cama...o-starter.html
Originally Posted by Drew
Old Jan 23, 2020 | 02:47 PM
Engine: 350 TPI L98
Transmission: WC T5
THAT is cool.
Old Jan 23, 2020 | 03:49 PM
Drew's Avatar
Most of the PMGR (permanent magnet gear reduction) starters are going to have the whine from the gearing. "They" said the PMGR starter I put in my Mustang several years ago would whine, but I really can't tell any difference. Fortunately I did the swap to get away from the 1966 Ford technology of the factory starter, so it didn't bug me. Point being, I wouldn't expect anyone will even notice a difference. You might not even be able to hear the difference from inside the car, FWIW. The PMGRs do seem to pull less on the battery, and whirl over with more authority, in addition to being smaller, and lighter.
Old Jan 23, 2020 | 08:05 PM
Vader's Avatar
The only reduction gear starters that sounded different were the 1960s-70s Chrysler starters. They sounded like a can opener turning a can of bolts.
Old Jan 23, 2020 | 10:33 PM
I really don't know what my starter sounds like. The LT1 fires over fast, and man does that cam sound good.
Unless the OP is talking about something like McLaren did for the 720s. The "hot start".
Old Jan 23, 2020 | 10:44 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
That's dumb.
I can make my engine burst to life too by opening up the the IAC parked position during crank and adjusting the ramp-down time to idle as a function of coolant temp. I do it in my Holley EFI tune when coolant is hot.... and it doesn't take 30 seconds of fiddling with gizmos and a flip screen.
Old Jan 23, 2020 | 10:56 PM
I can do it by cracking the throttle as I crank the car. But I'd only do it when it was warm, and recently running so I'm sure of lubrication.
However for the 720s? Hypercar life. The 720s is a sick, sick car. So fast. They've cracked 9's BONE stock. Thats nuts. And this is a car that can handle, not a Demon with a drag pack. And with minor bolt-ons and stock turbo's they are approaching the 8's.
Old Jan 24, 2020 | 09:22 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
I swapped the OEM starter for a GM mini-starter when I did the 383 and cleared the headers great. When I built the 421 which has larger headers I switched to an MSD starter which turn my 13:1 compression motor a lot easier. it about same size as the GM mini starter and it is clockable so "0" issues with header clearance.
serpentracer
Apr 23, 2010 02:22 AM
85Firebird350
Oct 20, 2007 04:03 PM
Abubaca
Jun 18, 2005 08:26 PM
Blue-Z28
May 17, 2003 12:20 AM
