1st track times with 85 305/5 speed
Old Jan 14, 2002 | 10:03 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Ok. The mods are open element air filter and flowmaster with a hollowed cat. The rear end has 3.42
First run
60' 2.34
1/8 10.42
mph 69.65
2nd run
60' 2.17
1/8 10.01
mph 70.45
3rd run
60' 2.34 (tranny mount broke)
1/8 10.34
mph 69.78
Sound right? What other mods should I do?
Chris
Old Jan 15, 2002 | 11:37 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Actually, I found out the car does have 3.42 after pulling the cover, I guess the speedo is off
Anyone???
Old Jan 15, 2002 | 12:15 PM
SoCo80p's Avatar
1/8 mile?
Old Jan 15, 2002 | 03:05 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Yes. It is
Gotta start somewhere
Old Jan 15, 2002 | 10:15 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Your best run would coorespond to around a 15.5-15.6 in the 1/4. The other runs right up around a 16.0. Not too bad. (rough estimate is to multiply 1/8th time by 1.55 to approx 1/4 time) That is an LG4 right? What mods? You sure it's 3.42s, stock should be 3.23s according to the tech database...
Old Jan 15, 2002 | 10:35 PM
Alan84TA's Avatar
Track times
My first run in my '85 305HO 5sp was 16.3 My best run now has been a 14.9 @ 96mph.. Only mods are K&N, hooker catback and pulleys, I also advanced the timing and that made a big difference... that was with a sucking 60' of 2.39 I have an intake, roller rockers and some slicks that will go on this spring... should be me into the low 14's or better...
Old Jan 16, 2002 | 10:13 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Mine is an 85, but an LG4 with the peanut cam. I think i will play with the timing some next, what did you find to be a good setting for yours??. Yeah we pulled the cover and it is 3.42. I have some 3.73. would that be too low for the car?
Chris
Old Jan 18, 2002 | 07:10 AM
Alan84TA's Avatar
I think I went with a base setting of 8 BTDC. I have 3:73s in mine... If you are planning on doing more mods I would go with the 3:73's...
Old Jan 18, 2002 | 10:01 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Yeah....once I get the posi for the rear I will probably put in the 3.73's.
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
novaderrik
Aug 10, 2015 12:44 PM
