Stalls when I'm driving I think it's iac valve help
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
I have a 88 gta
I went from a leaking working old stock tpi throttle body to a bbk 58mm one
and immediately I put it on and cold it starts and warms up at 1000 rpm and goes down to 750
but it seemed low
I know my old one was cold 1450 warmed up 750 the seals in my tb were leaking bad
but I havnt barly drove it yet
I took it for a ride and as soon as it gets hot it stalls when I press the clutch in at the lights I have to keep it going gas pedal
now I have a full tank of gas in it
when it's sitting ideling hot it runs forever without stalling
I don't get what's going on
my mom said it stalled randomly when you filled the gas full so she only filled it to half or 3/4 And it went away
the iac is original
is that what I should change first?
but it seemed low
the iac is original
Re: Stalls when I'm driving I think it's iac valve help
Maybe not "change"; instead, maybe "clean" and "set minimum air". There's about a million posts on this site about minimum air, Google the site for it/ (Google search... type in "minimum air" with the quotes, then "site:thirdgen.org" without the quotes.
The IAC doesn't really "go bad" that kind of way. It's more digital... usually either it works, or it doesn't. They do wear out and such as that but it's not common.
I'd try the other first.
Engine: 383 built
I can't find a rpm setting for my 88 tpi 5 speed
450 rpm for automatic
but nothing for a modded 383
what rpm do I set it to
I'm gonna do it tomn
For the purpose at hand the engine size doesn't matter. Use 450.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If you have a scanner use iac counts. 20-25 engine warm.
Engine: 383 built
It's fixed without a new iac
I did what you said
I set it at 550 to 600 and I drained out 20l and now the car is no more stalling
no joke
so ty
if it does this again I will tell you
and on my joy pimp my rear passenger brake was half locked on from a stock ebrake cable
I'm gonna get some new ones tomm
but I just wanted to say ty
no joke
so ty
Engine: Lb9
Transmission: M20
Drained your what ?
and your joy pimp ?
and your joy pimp ?
Engine: 383 built
I took 20l of gas out and pimp ride means a spirited cruise srry
Car: 1989 Camaro IROC Z
Engine: 383, soon to be an LS Stroker
Transmission: 700R4 - Switching to 4L80E
Axle/Gears: 10-Bolt/3.42 will be Moser 12-Bolt
emmanuel33v
Apr 11, 2010 04:49 PM
