3.4 4th gen vs 85 Z28 3rd gen
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
This guy has been wanting to race me for a while. I think I've got what I need to beat him. He has a 1996 Camaro w/ the 3.4 engine. The only mod he has done is a Flowmaster muffler. I've got a 1985 Z28 w/LG69 305HO, Holley 600 carb, no egr, no smog, MSD distributor, dynomax muffler, 1" carb spacer. Will I have any problems?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
should be close but I feel confident you will eventually pull on him. They got close to if not 200hp to your 190 stock. With your mods i guess 210-220 so at a bit lighter weight you should win if you run good, launch good.
Engine: L69
Just for the record, I have the 305 high output engine(code G). At least that's what my VIN tells me. It came stock with the dual snorkle air cleaner, which I was told was only included in the L69 engine.
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
is this a double post. also u should win if u have a man and he has a auto i won and i was going against a 96 v6 and mine is a 84 z l69 won by 1.5 cars
Car: 93 SHO
Engine: 3.2 liter
Transmission: Automatic
iirc you have 150 hp stock w/ 240 lb/ft. He has 160 hp w/ 200 lb/ft. It may be closer than you think.....but its late and i forget what trannies you said you both had. But thats actual power levels there.
ok
85 Z28 M5,A4 LG4 V8 9.5:1 5.0 (305) 155@4200 245@2000 4V 3.23 ---- 3.08 ----
3.4 liter/207 cid Horsepower 160 @ 4600 Torque (ft/lbs) 200 @ 3600
ur car will make max torque at 2000 rpms u should get him of the line and just keep on pulling.
Well which is it, a 96 or a 3.4L? The 93-95 cars got the 3.4L, and the 96-02 cars got the 3.8L. The 3.8L has 40 more HP and a similar torque increase. You'll take the 3.4L easy, but the 3.8L might take you.
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Was the 3.8 the standard option in '96? I thought that was kind of the crossover year with most of them getting the 3.4L but some getting the 3.8L...or was the crossover year '95? I thought it was '96..
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Pre '95 = 3.4
Post '95 = 3.8
'95 = Both engines
The 3.8's have 200hp and can run low to mid 15's stock. I have seen some run 12's with spray.
Originally posted by ShiftyCapone
The crossover year was '95 and you could get either the 3.4 or 3.8 for that model year only.
And only a very well driven 3.8L M5 is a low-mid 15 second car. The autos are usually a half second slower.
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
If it's a 3.4 it's a higher 16 second car. If it's a 3.8 it's a mid 15 second car. I wouldn't worry about the 3.4 in a 4thgen, the car is WAYY too heavy to make good times with that motor. Stick it in a lighter car though and....well you never know. I seen a few Mazda Miatas with 3.4L V6 swaps they turn low 13's or high 12's...freaking amazing for 160 hp/200 ft/lbs
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
Dude, you will waste him. Trust on this one. We have plenty of 3.4L's in out club and mufflers and such are still slow. The 3.8L is a lot faster, the 3.4L is no biggie. One of our guys is building a 3.4L with heads, cams and such, even then you would have a good chance. Waste him already.
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
If it's a 96, it has the 3.8L and will probably start passing you around 50mph. If it indeed does have the 3.4L for some strange reason, you'll win. My buddy and I raced when I had a '94 with a 3.4L and he has a '85 T/A bone stock except K&N and no exhuast from the cat back....me with only my flowblocker and ebay-style CAI. He owned me, from a roll and a dig. Both cars were autos and everytime they shifted, he would gain about a car on me. Just a little food for thought.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If he has an L69 (G says he does) then he has 190hp and 240 ft-lbs. He should also have a 5-speen manual and 3.73 gears.
190hp doesn't sound like much, but its a pretty potent engine. That engine likes to rev, and the trans and gears let it do that.
Car: 89 Iroc-z
Transmission: TH400
L69's make power peak at 4800 rpm. Not exactly revving but 3.73's would work good for that and be shifting at like 5300 rpm.
well
85 Z28 A4 LB9 V8 9.5:1 5.0 (305) 215@4400 275@3200 TPI ---- ---- 3.23 ----
85 IROC M5,A4 LG4 V8 9.5:1 5.0 (305) 155@4200 245@2000 4V 3.23 ---- 3.23 ----
85 IROC M5 L69 V8 9.5:1 5.0 (305) 190@4800 240@3200 4VHO 3.73 ---- ---- ----
85 IROC A4 LB9 V8 9.5:1 5.0 (305) 215@4400 275@3200 TPI ---- ---- 3.23 3.42
as you can see hte only h.o 305 came in a iroc. as while as the only L69 witch is the 305 h.o
the hole time i was under the impression your car had the factory motor i wish you would had said i swap it for a h.o 305 L69.
i still think u will win.
Originally posted by Nate86
Ahh, yes. The "good ol' days" of the raspy Flowmaster V6.
Seriously though, we have to race my new L98 against yours...then we'll see. Bwahahaha.
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
LOL why the hell did GM switch to the 3.4 ?
You have a lighter car, better engine, gesrs dont know but still ..
My money is on the V8
Car: '90 RS
Engine: 377 LSX
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Yup, the LHO was a funny motor - I had one in my '89 Grand Prix. That car wasn't very light either, but it had a good Cd. I always wanted to toss in a 3.4 DOHC motor in it... Except those motors (vin code X, right?) if they needed work, were a terror to work on, or so I've heard. I can see the need for more displacement for hte base motor when the 4th gen came out. My friend had a '95 with a 3.4, it seemed really sluggish - but then again, his motor was jacked up and knocked terribly, and the body lines were slightly crooked, ect... My L98 would've ate that car up without even trying. Heck, my WIFE'S car ('96 GP) could've beat him...
Engine: 3.0L/183
Bigger motor for a bigger car. The 3.1 in a 4th gen would have become a modern iron duke.
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Originally posted by 305RSlc
F*ck you HO!! My 3.4L just lost because I didn't have traction with my mad torque yo'. You're just lucky I didn't have a 3 foot wing to add downforce so I could beat you. And it would have been all over if I had NAWSSSSSSSSSSS!!!
Car: '90 RS
Engine: 377 LSX
I meant going to a 3.4 from a 3.8 .. makes no sense ..
Engine: 3.0L/183
my bad, they went from the 3.4 to the 3.8 ..
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Originally posted by Orr89RocZ
i dont know, but bigger is better in my opinion!!
There is no replacement for Displacement.....
even if it is just .4 of a liter...LOL
1992rs/ss
Jan 31, 2025 05:10 PM
ambainb
Apr 25, 2016 09:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
