305 and 350 TPI's
Old May 23, 2002 | 09:10 AM
Four12'sCamaro's Avatar
305 and 350 TPI's
is there any difference between the 350 and 305 set-ups? and also, are the manifolds different size???
Old May 23, 2002 | 09:32 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
the intake and fuel injection setups are the same unfortunately.
bad for the 350 but cost effective for gm
Brian'sIROC's Avatar
The only differences I know of (other than bore) are larger injectors, different programming and a different knock sensor. That's it.
Old May 23, 2002 | 10:21 AM
Steve89GTA's Avatar
Brian - you got it right on the money.:rockon:
Old May 23, 2002 | 12:56 PM
86IROCZ's Avatar
Thank you so much, I was just discussing this with my friend (who has a 1st gen). He had the opportunity to buy a TPI for the 350 he's building, but the TPI was off a 305. I told him exactly what Brian said, but my friend said that the runners on a 350 were larger.
Old May 23, 2002 | 01:03 PM
Steve89GTA's Avatar
You can even run the 19lb/hr on 350's (i've heard). I'd probably get the 22's though...or are they 24.
Old May 23, 2002 | 03:18 PM
johndo1707's Avatar
they are 22's but 19's will work better than the 22's with an afpr. thats what i'm going to be doing on the new motor i'm building.... good luck!
Old May 23, 2002 | 03:19 PM
You can run the 305 injectors (19#) in a fairly mild 350 if you get an adjustable fuel pressure regulator. I just read another thread where some guys ran the 305 knock sensor and memcal(chip) in their 350's with no problems. Oh, the runners are the same.
Old May 23, 2002 | 11:06 PM
camaro6spd's Avatar
ummm....i would go with 22lbs....lowers the PSI and the work on the fuel pump.....
Old May 24, 2002 | 11:33 AM
johndo1707's Avatar
cheaper for 19's but depends on your budget....if you go with 22's you wont have to worry about fuel pump, but even with the 22's i'd use the afpr becuz the fuel is spread out more causing better combustion....
Old May 24, 2002 | 11:35 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Is the fuel pump the same on both 305 and 350 cars?
Old May 25, 2002 | 12:03 AM
Swapmaster's Avatar
The fuel pumps are the same. The 305 injectors run at a higher
pressure to match the flow of a 350 injector will atomize the fuel
better giving better performance but will cause extra stress on
the pump. If it is not a daily driver, I would not worry about it.
But if it is a daily driver, the pump will die sooner than normal.
I use 19lb injectors on my Jaguar but the car only gets driven a
couple hundred miles a year.
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
