running really really rich!!!!! help please
Old Mar 9, 2003 | 10:32 PM
383LT1intake's Avatar
Car: 92 camaro
Engine: 383 stroker
Transmission: probuilt 700r4
i jus started my car and drove it and its running really really rich my o2 gauge is all the way over and my scan tool show 988mvts and doesnt move i jus got done with cam swap and swapped to 30# svo injectors and 7730 ecm with heated o2 its pegg rich on 02 guage the second i start it but i get no codes for being rich blows lots of black smoke i have a ed wright chip but i put stock one back in but its still the same any ideas? bad 02? thanks guys
Old Mar 9, 2003 | 11:46 PM
Bort62's Avatar
If you have got 30 lbs injectors and a stock PROM - Yeah.
No mystery there.
Old Mar 9, 2003 | 11:50 PM
xanax's Avatar
you didnt say if your ed wright chip was for the 30# injectors and your new cam or not. those two will cause rich running without tuning. especially on a 730 ecm
Old Mar 10, 2003 | 04:51 AM
Car: 92 camaro
Engine: 383 stroker
yes chip is set up for the cam and injectors and all
Old Mar 10, 2003 | 06:55 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Get a Adustable Fuel Pressure Reglutator (AFPR) and lower your fuel pressure.
Old Mar 10, 2003 | 09:39 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Have you modified your lower ve table?
Old Mar 10, 2003 | 10:17 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
You're certainly a trusting fellow. What you are describing sounds exactly like what would happen with the injector constant being that far off. And since it acts the same with both chips, if i were in your shoes, i would assume that ed wright sent me the wrong chip, or that something is wrong with it.
Granted there are a lot of other things you can screw up during a cam swap to make it run badly, but if it is specifically blowing lots of black smoke and way rich, i would lean towards the cal being completely wrong. If you had some opther problem it would just get a lot worse with the stock chip IMO.
Old Mar 11, 2003 | 04:28 PM
Mike Massey's Avatar
383 im xperiencing the same problem with my 383 mini ram and 30 lbs svo injectors also have ed wrght prom calibrated for them. I also noticed i have glowing headers at night and high exhaust temps. He told me my problem was in my timing or my compression.
I have had all checked and mechanically im a okay. I believe it is a prom tuning issue
Old Mar 11, 2003 | 09:04 PM
Bort62's Avatar
With an aftermarket cam and Those injecotrs, you are really going to have to do more than set the injector constant to 30lbs to get it to work right at idle.
ON a completely stock L98 GTA w/ supercharger, I had to absolutely murder the lower VE tables with those injectors to get it off 108.
Old Mar 12, 2003 | 08:10 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Ed Wright burns his chips really rich. I am not surprised at all.
Tim
Old Mar 12, 2003 | 09:44 AM
Ed Maher's Avatar
Car: 04 GTO
I'm just wondering. With a few thousand dollars in go fast goodies, when does it become cost effective to add a cheap laptop and free scanning software so you can actually see what is going on in there?
For much less than the price of a throttle body you could have had a laptop and know exactly what the ECM sees and is doing. Even if you don't want to burn your own chips, if you can't do any datalogging, anything that Ed Wright sends you is still going to be a total WAG.
edit: I just realized you said you got the O2 voltage from a scan tool. So the question becomes, what else do you see on the scan tool? Can you actually drive the car and get it into closed loop? How are the BLMs if so. If it's just a case of running ridiculously rich, as said, probably just a case of the chip being way off. No surprise there, thats why everyone who expects results burns their own.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
