I Gots Problems
Old Aug 6, 2003 | 12:09 AM
KtuluX's Avatar
Car: 87 Trans Am
Engine: 5.0 TPI
Transmission: Automatic
I Gots Problems
So, I just bought an 87 TA and the car was stored for the whole winter. It hasn't been ran at all in a few months. I run it now and it has a sputter when it starts to go. When I give it a little bit of gas, it sputters, but when I hit it hard, it goes. Its odd. Any suggestions? Its a 5.0L TPI. I tried Fuel Injecter Cleaner already.... anything?
Old Aug 6, 2003 | 07:38 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Try a tune-up if one hasn't already been done.
Old Aug 6, 2003 | 10:30 AM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
90% of that FI cleaner is crap so you probably won;t get any to make any sort of difference. I agree with Kt, get a tune up taken care of and a really good visual inspections of all connections and what not. The tune up should do it though...at least we would like to think so.
Old Aug 7, 2003 | 08:40 AM
Steve89GTA's Avatar
The only fuel cleaner that matters is that b-12 chemtool stuff. Other than that, I'd pull the plugs and see what they look like. The plugs are the best diagnostic source for our cars... Look for heavy fuel or oil deposits, broken electrodes, white residue...etc
Old Aug 7, 2003 | 10:22 AM
EYEROCK89's Avatar
Car: 1989 IROC
Steve - Exaclty, thats the only stuff I use and I put it in everything I have that runs on gas. check the plugs and see if it helps any. Lol, make sure a rat didn;t get up in your intake and die....
Old Aug 8, 2003 | 02:48 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Where do they sell this b12 stuff, and is it direct application, or through the fuel lines ?
Old Aug 8, 2003 | 03:47 PM
biff85ta's Avatar
Car: 04 Vette
have you gotten rid of the old gas it has probaly broken down fill the tank with premium and see if that helps other than that a good tune up can work wonders.
Old Aug 8, 2003 | 07:02 PM
Justbrilliant5's Avatar
fuel filter
change the fuel filter and clean up the IAC with carb cleaner. Reset the IAC..
should be good to go /
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Fronzizzle
Aug 9, 2015 01:15 PM
