Puel PUMP
Car: 88 Camaro IROC
Engine: 5.0 TPI
Puel PUMP
I have an 88 Iroc 305 TPI. I drove to university of washington today and watched the Huskies get stomped by Navada but when i can back my car wouldn't stop. I don't here the pump whining and when i pushed in on the shrader valve on the fuel rail there was nothin. It has a full tank of gas in it (go figure) I have been experiencing hard starts so I replaced the pump relay, didn't help. I bought the car in april or may and was told the car sat for a year. (no gas in the tank when i picked it up) Sound like a fuel pump? HELP PLEASE
Car: 1982 Z28
If the pump's not priming (runs for 2 seconds when you first turn the key to RUN position) next step is to verify it's getting voltage.
There's a 3-pin connector near the tank on the driver's side, easily accessible. Figure out which one's voltage (it varies) or just use a test light and test each one. Have a buddy turn the key to RUN while you probe each pin.
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I am not sure on your 88 but on my 92 there is a fuel pump test on the ALDL. On mine it is the lower left terminal. Use a test light to jump 12 v to it and you should here the pump turn on. I would also do the test Kevin mentioned above. Good luck...
Car: 88 Camaro IROC
Engine: 5.0 TPI
I was told by my friend's dad that if the ignition modual goes out that it won't allow the fuel pump to turn on. Is that true?
Car: 1982 Z28
After this, the ignition module comes into play and if the ECM doesn't see reference pulses it won't close the fuel pump relay...but the oil pressure switch will usually close while the engine's turning and feed voltage to the pump anyway.
Car: 88 Camaro IROC
Engine: 5.0 TPI
Well i checked for power at the fuel pump and there is for the 2 secord prime, but still no noise from the pump. Sounding more like the pump everyday.
Car: 1982 Z28
Good troubleshoot. I highly recommend the Walbro 255 or 340 pump, both are drop-in replacements and will keep up with whatever fuel needs your engine has. Personally I like the 340 better, because it draws less amperage at the same delivery pressure.
This guy has a good reputation:
http://www.autoperformanceengineering.com/
http://www.autoperformanceengineerin.../fuelpump.html
Car: 88 Camaro IROC
Engine: 5.0 TPI
i'd love to get a hi-perf one but i don't have the cash or the time to wait for it to get to me.
Car: Guess
Engine: Crazy 8
WOW!! That guy has some good prices for the Walbro. I got mine from Thunder Racing and paid about $150. That is a Holley pump but it is made by Walbro.
To bad you don't have the money to get the high flow pump now because pulling the tank to change out a pump is not the most fun way to spend a weekend...
Hotrodboba400
12-10-2019 07:07 PM
