what cam???
Old Nov 17, 2003 | 11:16 AM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
what cam???
ive decided for my 85 T/A i am going to use iron vortec heads, the vortec manifold base, possiblly aftermarket runners with my stock plenum ported, stock throttle body with an airfoil, a adjustable fuel press. regulator, an aftermarket chip, 3" Flowmaster cat back, and shorty headers... i was wondering if anyone could reccommend which cam i should use, i would like to stay with roller valve train...
CompCams computer controlled TPI cam?
Lingenfelter L98 cam?
ZZ4 cam?
LT1 hot cam?
Custom grind??? what duration and lift???
(the car has 4.10 gears and a 2500 stall converter)
Old Nov 17, 2003 | 11:27 AM
biggtime's Avatar
the 211/219 lingenfelter cam would work great, but you would have to change the springs on the heads.
.499/.525 with 1.5 rockers
211/219 @.050
clc-112
icl-108
great camshaft for NA tuned ports. I have one if you are interested. used on dyno. I changed the engine to boosted.
Old Nov 17, 2003 | 11:35 AM
biggtime's Avatar
I forgot, instead of the vortecs why don't you look at the edelbrock performer centerbolt heads. buy the time you bought the vortec heads and tpi base you could have these and they are much better. The edelbrock heads on a 350 with the 211/219
cam, 10:1 comp. makes 300-325 to the wheels.
Old Nov 18, 2003 | 11:46 AM
Car: 91 camaro rs
performer heads
thanks for the advice, the lingenfelter cam does look like a good choice with decent lift and short duration, and as far as the performer heads go i understand what u mean about them being the same cost as the vortecs and the vortec manifold, but if i run the performer center bolts, is my stock intake base gonna flow enough or will it really restrict it??? i plan on runnning my stock runners and stock plenum ported (possibly upgrading to edelbrock or accel later on), with the stock throttle body with a TPIS airfoil, and i'll have an adjustable fuel press. regulator.
any help will help alot...thanks
Old Nov 18, 2003 | 02:25 PM
biggtime's Avatar
You can put the biggest manifold on but it still will only flow as good as what is feeding it. The runners and manifold need to work together. I have built this combo a few times for people and it is a great street engine for a 350. You doing this to a 305 will not need as much flow as the 350. If you only have limited funds now but plan on making changes down the road don't buy parts twice!The vortec heads are a good for stock to a little more. Just my opinion. The edelbrocks can be bought for 1,000.00 and bolt on tomorrow.
Just my $.02
Hope this helps.
Old Nov 18, 2003 | 05:51 PM
Car: 91 camaro rs
tpi build up
thanks for your incite, and advice, i appreciate it.
my car does have a 5 liter now, as listed in my name, but my build up will be done with a 350. i am using a 350 short block with probably 10:1 pistons. i am aware that i have to step up the size of the injectors from the little 19lb/hrs, but what size would you reccommend?? 22lb/hr?, bigger?
i see what u mean by building it right the first time, and i am pretty sure that i'll get the edelbrock heads instead of the vortecs, and use the lingenfelter 211/219 cam, hopefully this will provide a strong foundation for my T/A, as i hope to get involved in some drag racing this coming spiring. my goal is to eventually stay with, or beat my uncle's 1968 GTO thats been restored from the ground up with a 400/4speed(right now he runs a 12.9-13.2 naturally aspirated on slicks)
any thing else that you think will help me with my build up or car in general would be greatly appreciated,
thanks for the great tips!
-Keith
Old Nov 19, 2003 | 12:17 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I wouldn't put the same parts on a 305 that I would on a 350. They are 2 different engines w/ different needs. That's like putting a 350's parts on a 400. I like to try and get the most I can out of a motor. A 350 is going to laugh at a cam w/ 211/219*. I say, save up and buy the right parts once.
Old Nov 19, 2003 | 04:33 PM
biggtime's Avatar
I have made 325RWHP with that cam in a 350, out of the box performer centerbolts, edelebrock manifold, slp runners,1.6 rockers. I'd say thats a pretty good combo. on a 305 it would be a really good combo.
But you are welcome to your opinion
Old Nov 19, 2003 | 06:55 PM
83 Crossfire TA's Avatar
Lingenfelter’s cams are much better (make much more power) then their rather tame published numbers would have you believe.
Old Nov 19, 2003 | 08:18 PM
Car: 91 camaro rs
choices, choices, choices....
the edelbrock heads and the lingenfelter cam definitely sound like a good plan, thanks for the pointer, thats the way i am going to go...i will let you know how it works out probably late spring when i get it built. 325 at the wheels sounds great, i can only imagine the torque output the car would have, i cant wait to drive my Trans Am with a breath of new life in it...
civics, integras, and 350Zs beware!!!
Old Nov 20, 2003 | 12:09 AM
Um, unless your engine is blown up and the car on jackstands, you should be beating those cars already...
Old Nov 20, 2003 | 01:06 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Not to be a moderator or anything, but does this have anything to do with nitrous or forced induction?
Old Nov 20, 2003 | 04:38 PM
Car: 91 camaro rs
good point about the jap craps, i was just jokin around making fun of the import guys who think there fast,
and about the wrong category(power adder) sorry about that i'll put it in the right category next time, it was one ofd my first posts, im new, Sorry.
Old Nov 21, 2003 | 07:45 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
No problem. It's now been moved to the TPI forum, where you'll get more replies.
Andris
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
