383 tpi help
Old Feb 12, 2004 | 04:31 PM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
383 tpi help
well i finally got my car working. its a 383 stroker what should i set my setting like tps and fuel pressure at?
Old Feb 13, 2004 | 12:20 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
My tps is as high as it will go without setting a code which is .60-.62. Fuel pressure is up to you. Mine is at 48psi.
Old Feb 13, 2004 | 12:27 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
TPS voltage is factory at .57 I believe. Going higher will net you a bit of a performance increase. .62 is about the practical limit.
Fuel pressure depends on what the motor needa at WOT. Higher pressure and lower pulsewidth will improve atomization and performance. Take some EGT readings and figure it out.
Old Feb 16, 2004 | 03:09 PM
demon138's Avatar
its weird sometimes when i drive my car the idle will surge up and down. sometimes surges so low my car dies. what could that be?
Old Feb 16, 2004 | 03:36 PM
VSS not working properly springs to mind. Could also be a short in the park/neutral switch if it's an automatic.
Old Feb 16, 2004 | 05:17 PM
demon138's Avatar
its maf and the park neutral switch could cause it to surge?
Old Feb 16, 2004 | 05:22 PM
The VSS is the vehicle speed sensor. It helps to govern the control of among other things the IAC and EGR functions. Later cars had a VSS in the trans, also used for speedo. Older cable drive speedo cars have a VSS built into the speedometer. It sends information to the ECM telling it how fast the car is going and other information.
On the shifter part of the assembly that plugs into the shifter mechanism is a park/neutral switch. If this switch is physically bridged or is shorting out (going to ground) it can tell the ECU that the car is in park or neutral when it is really in gear. This can lead to a screwy idle while in gear and stalling and other annoying problems.
Old Feb 17, 2004 | 01:52 PM
demon138's Avatar
thanks ill check it out
toronto formula
Nov 10, 2015 06:17 AM
bdads
Aug 24, 2015 06:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
