305 rpm range
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
305 rpm range
i havce a 305 tpi 5 speed and it pulls hard to 5200 rpms. i have stock runners base and plenum. do the stock 305's do that or do u think i might have a mild cam? like this one
Car: 1983 G20 Chevy
Transmission: 4L60
My stock 305 didn't stop pulling to about 5,500. The factory 1-2 shift point was 5,000 rpm and this is a van engine. The TPI car I would think would be better.
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
i have taken it to 6500 on a hard race, and past 7000 once(to fix my tach), dont take it past 6K you can throw a rod, you can lose a bearing, Break a valve spring, bend a pushrod, cut the cam etc. So 6000 is as high as i would run it.
Remeber the 305 was only designed to go 4500, try not to go too far past the 5500 redline 6000 should really be a max out. Any farther than that and you are hurting your car. Remeber valve float as well.
Oh i have a tpi five speed w/ 3.45's.
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Your camshaft yes it will pull to 5200, get rid of that 85mph speedo.
Gm part# 14093643*
Lift:.404/.415
Dur:202/207
LSA:114.5
RAR: 1.5
Gm part# 14093643*
Lift:.404/.415
Dur:202/207
LSA:114.5
RAR: 1.5
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Gm part# 14093643*
Lift:.404/.415
Dur:202/207
LSA:114.5
RAR: 1.5
Gm part# 14093643*
Lift:.404/.415
Dur:202/207
LSA:114.5
RAR: 1.5
Factory tachs tend to be a little misleading....
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Originally posted by GOY
My 88 Formula 5spd has a slightly larger cam I beleive. I'm done and over with by around 4800-5000, but that could just be a difference in factory tach calibration, etc.
exactly . Mine pulled to 4800ish . Now it's still the same ( different motor I know ...but ) ...With the porting of this intake .... the
" brick wall" is less pronounced.
Car: 1989 IROC-Z
theshackle
Sep 17, 2020 08:26 AM
