engine shutting off problem
Old Feb 22, 2007 | 06:05 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
i'v got an 85 iroc-z with tpi and the engine will cut off after i'v been driving on the highway for a while and come to a stop but stop and go is fine. any ideas?
Old Feb 22, 2007 | 11:25 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
This actually happens to me too. Its only happended a handful of times and not enough for me to notice a pattern. Once I was in line at the track and it cut off , but like you, I just cranked it back up and continued...
I would think it was some sort of safety cut off when the engine gets too hot (since I was in line for a while) but I also remember that when my water pump was going, the engine temp. got to redline and it still didn't shut off (I turned it off and waited half and hour before I drove the rest of the half-mile home)..so I'm not sure why the cut off, I wonder if anyone else has this issue...
Old Feb 22, 2007 | 11:52 PM
ShMaCk2004's Avatar
its not a cooling problem, it does it almost every time i come to a stop after cruising for a while
Old Feb 23, 2007 | 11:11 PM
HCR13's Avatar
Car: 1987 Trans Am
It hasn't happened to me recently, but it does happen while I stop. Never while driving...
Old Feb 23, 2007 | 11:32 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Be more specific.
A coughing/sputtering type stall will more than likely be fuel.
A clean cut out/stall tends to be spark.
Bad injectors overheating the driver will cause intermittent shut down.
Bad cylinder head grds(pass side)
Bad pickup coil or module.
Weak or dying fuel pump.
Stuck open egr.
later
Jeremy
Old Feb 24, 2007 | 01:24 AM
ShMaCk2004's Avatar
i think it may be the smog pump not being hooked up...i'll replace it and see if its it.
Old Feb 25, 2007 | 12:16 AM
HCR13's Avatar
Car: 1987 Trans Am
I still have my smog pump and A.I.R. system and its done it to me...
Old Feb 25, 2007 | 02:10 AM
ShMaCk2004's Avatar
wasnt the smog pump...moved on to cap and rotor...still same.
Old Mar 29, 2007 | 12:35 AM
Colts45s's Avatar
Car: 92 camaro rs
Engine: 350 tbi/416's/comp xe268
Re: engine shutting off problem
keep us posted id like to see what you find
Infested
May 22, 2018 11:56 PM
wayshegoes
Aug 17, 2015 12:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Fronzizzle
Aug 9, 2015 01:15 PM
