Eldelbrock High-Flo standard base with Vortecs?
Old 03-04-2007, 10:53 PM
Metalhead's Avatar
Car: 89 Trans AM GTA, 99 Olds Alero GLS
Engine: TPI 350 L98
Axle/Gears: Borg Warner 3.27
Hi, I tried doing a search but didnt find what I was looking for. Im sure this has been asked, but I was wondering if I could take the Edelbrock High-flo base for stock heads and use vortec heads with it? Will I have to re-drill some holes? If so which ones? I hate to buy a new base just for these heads. Are these heads worth the money over my L98 heads I have now?
Metalhead
Old 03-05-2007, 05:16 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
If you are planning on AFR heads why would you want to worry about Vortec heads?
Old 03-05-2007, 08:55 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
one of advantage to vortec heads are the combustion chamber. the combustion chamber on the AFRs would be the same for both. the only other is the bolt location and the vortec's have a taller/narrower runners.
a stock vortec head is much better than the L98, but to answer your question no, you can't do that.
Old 03-05-2007, 10:27 AM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
I have a high flow vortec base I will sell for 400.
Old 03-05-2007, 05:40 PM
Metalhead's Avatar
Engine: TPI 350 L98
Yeah I was thinking about AFRs but 1500 is alot to dish out. I work at a dealership and can get a set of vortecs cheap. Thats why I was thinking about going that route. If I have to buy a new base then it isnt worth the money then.
Metalhead
Old 03-06-2007, 12:42 AM
Well, I run Vortec's and I love them. But you do have to buy a new base to run them. Personally I'm looking very hard at the new ARF Eliminator heads.
Old 03-06-2007, 05:22 PM
Metalhead's Avatar
Engine: TPI 350 L98
Yeah thats what I was looking at was the new Eliminators. They make them sound really good. Of course the old AFRs were good anyways. I was thinking somewhere on here I read that you could drill out the base but I guess I am thinking of something else or read it wrong.
Old 03-06-2007, 05:34 PM
bonz's Avatar
Car: 89 GTA
You can modify a stock base to work on vortec heads but its not the best idea. Ive heard of people doing it but they have battled vacuum leak since you have to use 2 intake gaskets to get it to seal.
Mods. GMPP Vortec heads, Comp Cams XR269HR, Crane Gold Rockers, Hooker headers, SDPC intake manifold, free flow exhaust, Air Foil, descreened maf, TB Bypass, K&N filter. Future mods, TPIS Runners, AFPR.
Fronzizzle
02-09-2017 09:31 AM
69GTOby
04-18-2016 02:34 PM
BLK87Z
09-18-2015 11:29 PM
Liveaction
09-17-2015 06:29 PM
scottmoyer
09-07-2015 07:06 PM
Quick Reply: Eldelbrock High-Flo standard base with Vortecs?
