Best Plugs and Wires for a 350 GTA?
Old Nov 2, 2000 | 04:35 PM
MY87GTA's Avatar
I was wondering what the best wires and plugs are that i should use in my 1987 350 GTA?
Old Nov 2, 2000 | 04:47 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I like regular AC plugs and Taylor 8mm Spiral Pro
Old Nov 2, 2000 | 04:55 PM
black5.7GTA's Avatar
I have Bosch plat+4 in mine.Rapidfires are also good,but I would get platinums because they last longer and I wouldn't want to change them again because thy are a PITA.As far as wires I have SLP's but their disc.TPIS ,and Performance Distibutors also make excellent ones to,the TPIS ones look factory and cost around $50, the Performance Dist.ones are red and cost around $100.I would also change your module,coil,cap,and rotor if you haven't already.
Old Nov 2, 2000 | 08:02 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Wires are easy, MSD Super Conductors. Lowest resistance wire on the market (less than 50 ohm/foot). I've tested them against other wires and I was amazed how good they are.
Plugs are another thing. You can buy those gimmicky plugs...but what you want is to open up the "flame kernel" as much as possible. I've tried platinums and others, frankly I prefer good old AC Delco. Just grind back the top electrode a bit so you can see half of the center electrode in the insulator. This exposes the spark flame to the combustion chamber better than any "gimmick" plub. If you have a good coil and good wires, gap your plugs a little wider from the stock .035" to .045".
Old Nov 3, 2000 | 08:42 AM
FormulaGod's Avatar
For plugs, go with good old A/C delco. Wires, go with taylor 8mm cables.
Old Nov 3, 2000 | 04:22 PM
MY87GTA's Avatar
Does AC Delco make only one kind of plug? I'm assuming they make more than one kind, which ones do i want?
Old Nov 3, 2000 | 04:33 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Regular AC's not rapid fires
Old Nov 3, 2000 | 04:37 PM
MY87GTA's Avatar
Whats wrong with the Rapid Fires?
Old Nov 3, 2000 | 04:43 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Nothing, but I dont see the need to spend the extra Money. I have found that the regular ones wear better with my 6AL box.
Old Nov 4, 2000 | 04:48 PM
MY87GTA's Avatar
I have the 6al box, so i'll most likely get the regular rapid fires.
Old Nov 5, 2000 | 08:12 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
The BEST wires are probably Magnacores...but they are EXPEN$IVE.
Whatever plug you buy get platinums, b/c they are a PITA to change.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 160,000 miles, K&N filter
specialized
Jun 18, 2022 09:26 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Brcharrelson
Aug 26, 2015 07:47 PM
Exxon Limited
Aug 9, 2015 08:13 PM
92projectcamaro
Aug 6, 2015 01:20 PM
