Can a home made cold air setup be made out of???
Old Feb 12, 2001 | 09:52 PM
njdaewoo's Avatar
From: Newark,NJ> Where street racing on I 78 RULES!
How is every one doing today?
My question is, for a 86 tpi car can a cold air induction be made out of 3" exhaust tubing bent at a 90 degree angle before the throttle body, to an maf,, to a k&n air filter with some of that thermo rap around the metal tubing. The K&N air filter would end, inside the pass fender.
Do any one think that this would work?
thanx for any input!
njdaewoo
406 sb
dart 200 heads(out the box)
144 B&M blower
373 gears
Edl headers
3in cat back Flowmaster exh.
270 comp cams
12.50s @ 115mph
on street tires
60ft time 2.30
www.njdaewoo@excite.com
New Project car
86TPI trans Am
All stock for now
Old Feb 12, 2001 | 10:12 PM
steve8586iroc's Avatar
Why would the air in your fender be any cooler than the stock filter location in front of the radiator? I always thought this is one of the best places to pick up cool air as well as being easier to make a functional ram air set-up.
To answer your question, yes, anything is possible.
[This message has been edited by steve8586iroc (edited February 12, 2001).]
Old Feb 14, 2001 | 11:27 PM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
I agree with what was said before. You can do it I'm sure, but it is not very logical in my opinion. You have the air coming from in front of the radiator, before it ever gets to the engine bay. I'm sure temperatures there are much cooler than over by the fender. I could be wrong, but I don't know. Also, if you just use some dryer ducting, you can make one that hooks up to your fog light openings and then get cool air direct from outside. Just something to think about. Do whatever floats your boat. I do think that your idea would work though.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, K&N, MAF Sceens Gone, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Accel U-Groove Plugs, Accel 8.8 mm Wires, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace, One Loud Stereo!
Old Feb 15, 2001 | 08:21 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
yes that will work fine.
the other people that replied were thinking you had a camaro, but if they would read they would see you had a T/A.
Old Feb 15, 2001 | 09:11 PM
njdaewoo's Avatar
Yeah!! U tell them 88 305tpi/ta. Its a 86 trans am and that intake canister thing, is not the THE RIGHT ONE BABY!
Old Feb 15, 2001 | 09:37 PM
IROCET's Avatar
Engine: 5.7L
Even if he does have a TA, what I said will still work. If he has the ground effects with the fog lights, get some dryer ducting and make a ram air setup. If not, then you can run it from underneath the front of the car like the way March has their setup for the Mustang. Just making suggestions.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
Old Feb 15, 2001 | 11:55 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I know about the foglight install
I did it myself with homeheater venting aluminum and 4 inch aluminum dryer tubing.
see no foglight, I should have pics of install soon
<img src=http://www.geocities.com/transam617/spread2.JPG>
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax catback, urethane motor+trans mounts,
SSM SFCs, Bilsteins
very trick homemade ramair, Accel 300+ ignition system.
Planning: hedman 1-5/8 longtubes, NOS 150 plate, world 305 heads, replace the "peanut"! and other susp. mods.
check it out at:
Old Feb 16, 2001 | 01:31 PM
IROCET's Avatar
Engine: 5.7L
That is a very nice looking car. Are those white stripes running over the top? Have you had it repainted or anything? Looks good
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
Old Feb 17, 2001 | 12:03 AM
njdaewoo's Avatar
That is a nice a** car. Is it hard to keep a black car clean? I was thinking about having my car painted black this summer. I have a 86ta that was in a accident. The whole front end was smashed up pretty bad so What i did was installed a 87 IROCZ nose on the ta's body.I think it looks pretty good so far.Right now the car is maroon(TA rear section),new black front fenders, Iroc daytona raised hood (with the holes on the side) & white Iroc bumper cover.
njdaewoo
Old Feb 17, 2001 | 09:40 AM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
the car is custom urethane black base with silver stripes in the same color as the screaming chicken logos.
the car was painted 4 years ago like this and I just take real good care of it.
black is the hardest color to paint well but its worth it at night when It looks the best.
there are more pics on my site and I should have info and pics of my ramair install soon.
SSM SFCs, Bilsteins
check it out at:
Old Feb 17, 2001 | 02:54 PM
vortech305's Avatar
someone told me the best way for your motor to have good cold induction is for you intake duct to be in a straight line such as used in 91-92 z28's forget the 90 degree ducts. Believe it or not u can get about 2-3 hp just by doing this. Sure what is 2-3 hp but every little bit helps.
92' camaro
New 305 block TPI conversion, Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads accel cam,52mm throttle bodie, SLP runners,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods msd 8.5 mm wires hypertech coil and plug, Edelbrock TES headers, free flowing catalytic converter and a 3 ich force II flowmaster exhaust system.
Soon to come!!!
Procharger system 12lbs o boost.
Favorite quote: "where ever u go, there u are"
Terrell351
Jun 13, 2021 01:13 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyle5647
Aug 15, 2015 11:56 PM
drathaar907
Aug 6, 2015 04:20 PM
