vss different on t5/700r4
Well are they different. I was just wondering because I am thinking about buying a wiring harness from someone and wondered if it would be worth it to get the sensor.
Thanks for your help
Ben
Ben
Car: Faster
Engine: Than
Transmission: You!
If you are changing harnesses for a tranny swap, then I would get the correct sensor for the tranny that you will have. Or you can do what I'm going to do and say F*ck it, I'm tired of this pile of crap 700r4 and I'm going to put a 6-speed in it and be done with it!!
Actually I would love to have a t56, but I cant really afford it. I am actually collecting parts to build a tpi motor and currently have a rebuilt 700r4 with a mechanical speedo. I am thinking about buying a wiring harness from a car with a t5. I was wondering if the vss would work with my 700.
ThAnKs
Ben
ThAnKs
Ben
Definetly wont. The VSS and the connector for it are different!
1992 Z28 5.7 TPI
ZZ4 longblock
Harland Sharp roller rockers
Accel base and SLP siamesed runners,
52MM SLP Throttle Body
Hooker Headers & Flowmaster catback
MSD6A ignition
aluminum driveshaft
World Class 5-speed
1992 Z28 5.7 TPI
ZZ4 longblock
MSD6A ignition
aluminum driveshaft
World Class 5-speed
are you going from MAF to SD??
the SD uses a 4k pulse generator.
the MAF used a 2k pulse VS generator.
weve used generators for cable driven speedos
both 2 and 4k. just capped the output.
plus... there are gears in the tail and generator
to corelate the correct speed. unless you have
a VSS buffer.
airdeano
a VSS buffer.
airdeano
Actually I am starting from scratch. I am building the motor and going with the speed density style tuned port. I know that their are gears in there that tell corolate with the rear gears, but I was wondering specifically if a vss out of a speed density 5 spd camaro would work in a (going to be) speed density 700r4, which I believe has already been answered. So I guess I will just have to get a different sensor. I just wondered if I could use the same wiring and get a new clip that matched the 700r4 style sensor.
Ben
Ben
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep, just change the connector to match your new VSS in the trans, and you're good to go. The wires are the same color (purple and yellow) and go to the same place in the computer, regardless of trans.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
318 RWHP, 419 RWTQ
13.23 @ 107.62 MPH (2.13 60')
Southern California
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
318 RWHP, 419 RWTQ
Southern California
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
