CAR WON'T START
Old Aug 3, 2008 | 06:43 PM
BadBilly442's Avatar
Car: 2Trans Am convertibles91/92
Transmission: Auto's
Axle/Gears: Who knows
CAR WON'T START
Ok fellow Tpi owners your help is needed.. I have a 1991 Trans Am Convert. 305.. I just replaced all the injectors and the fuel pressure regulator with and adjustable BBk unit..got it all wrapped up tried to start it and it ran for a few seconds and quit..I attempted to adjust the reg. and no go.. can't figure it out.. i tried to adjust the reg all the way down to fully open and still nothing.. I should just go back to the stog reg.. lol..
Please help..
BadBilly
(As in bad at adjusting stuff)
Old Aug 3, 2008 | 08:44 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: CAR WON'T START
Please help..
BadBilly
just trade me for this car and life will be good!
Old Aug 3, 2008 | 10:23 PM
Re: CAR WON'T START
Sweet Car man.. But im keeping her.. thanks anyway..
Old Aug 4, 2008 | 04:51 PM
Re: CAR WON'T START
likewise!Sweet vert ya got there.get it figured out yet?
Old Aug 4, 2008 | 05:46 PM
Re: CAR WON'T START
No and it's pissing me off, Im getting fuel to the fuel rails but it sounds like it's not getting gas to the injectors.. im baffled??????? keeps stumbling and i don't smell any gas in the Throttle body..
Old Aug 4, 2008 | 05:50 PM
Re: CAR WON'T START
yeah,I don't get it either.Is the reg. possibly a defect?
You should still be getting fuel up there though right?
Old Aug 4, 2008 | 05:55 PM
Re: CAR WON'T START
I installed a BBk adjustable , got pissed at that thinking that was it. I took that off and installed a Gm factory fresh unit and like i said it gets fuel to the rails but keeps acting like it's not getting fuel to the injectors.. Argghhh Im Effing going out of my mind lol. and my Back hurts too im 6'4 and it sucks bending under the hood. i should have just let the mechanic fix the damn thing but noooooooo! i tell myself i can do it.. Ok i feel a little better ..
Sorry had a chick moment there..
Old Aug 4, 2008 | 06:13 PM
Re: CAR WON'T START
HAHA!!I know what ya mean about bending over that eng. comp. I'm 6'1.
Ok,no fuel to the inj.? hmm,possibly got blockage in the fuelrail??Have put a fuel pressure tester on the fuelrail port?
Old Aug 4, 2008 | 06:16 PM
Re: CAR WON'T START
That i haven't done, but i can release fuel from the schrader valve and it's under pressure..
Old Aug 4, 2008 | 06:23 PM
Re: CAR WON'T START
how far up does the fuel shoot?If it sprays out everywhere and hits the hood,then I would say pressure is good.But,really need the gauge to be sure.
I had a similar prob. with an old car,fuel pump came on and car barely idled(91 v6 bird) fuel press. check showed the eng. was only getting 11psi instead of 44+psi.New pump installed and car was good as new.
Old Aug 4, 2008 | 06:37 PM
Re: CAR WON'T START
Esssh i will check that out..
Old Aug 4, 2008 | 07:04 PM
Re: CAR WON'T START
Yeah,I just noticed under your user name 2 91 TA VERTS!!!!!??
Now thats just being greedy!LOL!
My offer still stands on the trade.lol!
Old Aug 4, 2008 | 07:07 PM
Re: CAR WON'T START
LOL! i just got rid of the Black one.. sold it to some guy in illinois he bought 4 of them, now thats greedy..i just have the red one now..
Old Aug 5, 2008 | 10:32 PM
Re: CAR WON'T START
OK im calling AZ TPI tomorrow..
Old Aug 5, 2008 | 11:18 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: CAR WON'T START
what injectors did you put in anyway
Old Aug 5, 2008 | 11:25 PM
Re: CAR WON'T START
i put in Accel 19 lbs 14.4 ohms
Old Aug 6, 2008 | 05:17 PM
Samdweezel05's Avatar
Re: CAR WON'T START
Just an idea here. I went through this a wile ago. The VATS in your car will not allow the injectors to fire if they do not send a 4-5 volt signal at 30hz to the ECM when you are trying to start it. Try and see if it will fire with a touch or starting fluid. This 4-5 volt signal is only needed to get it to start. If it stays running after you try the starting fluid I would look into you factory security system. I doubt the chip in the key is the problem because if it was, the car wouldn't even turn over. Pull the boot off the TB hold it at WOT and give it a shot of starting fluid. Clost the TB and start it. Don't use too much starter fluid or you will have biger problems. Good luck
Phil
Old Aug 6, 2008 | 06:39 PM
Re: CAR WON'T START
Ok i did that and it acted like it wanted to run, but it still sounds like it's starving for fuel. Mind you i started and ran before i changed out the injectors. it just had a miss in it that i had diagnosed and was told it had a bad injector which it did. So now i can't figure out why it won't start.. im gonna have it towed to AZTPI in the A.M. and have them figure it out as im fed up with it lol.. Plus im in AZ and it's hot in my Garage..
Thanks for the try phil..
Old Aug 7, 2008 | 12:01 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: CAR WON'T START
what kinda accel injectors? blacktops or metal?
Old Aug 7, 2008 | 07:32 AM
Re: CAR WON'T START
Metal
Old Aug 7, 2008 | 06:03 PM
Re: CAR WON'T START
EFFING!!!!! FUEL PUMP WENT BAD< HOW the hell does the fuel pump all of a sudden go bad???????, Well only after you spend quite a few hundred more dollars for the injectors and other stuff. esshhhh.. well i guess i have cough up the money .. at least she will be back on the road..
Old Aug 7, 2008 | 06:22 PM
Re: CAR WON'T START
Old Aug 7, 2008 | 06:23 PM
Re: CAR WON'T START
It sucks that it went bad but it could have been worse. Glad you will be back on the toad.
Phil
Old Aug 7, 2008 | 07:10 PM
Re: CAR WON'T START
Well im not back on the Toad LOL yet, Just kidding.. But hopefully tomorrow i will be.. then i can get the new Top installed barring any other hangups.
But thanks for all the info Phil.
Old Aug 7, 2008 | 07:15 PM
Re: CAR WON'T START
I was going to edit that but it made me laugh so much I left it there. Just don't follow the yellow d!ck toad.
Phil
Old Aug 7, 2008 | 07:18 PM
Re: CAR WON'T START
see,if you just traded me for the z28 you wouldn't have this problem now!LOL!
Glad to hear it was only the fuel pump man.(yeah they just go bad for no reason or warning)!!!
That sucks seeing it on a towtruck huh?
Really breaks my heart. If the shop hasn't started working on her yet,you can just give the towtruck folks my address and I'll send them back to ya with the orange beast!
Old Aug 7, 2008 | 07:34 PM
Re: CAR WON'T START
LOL!! too funny. hey i like your Z she looks sweet. but i have had 4 91 92 convertibles and i regretted selling any of them.. Especially my Med metallic red one.. here she is,, damn i miss her so..
I want her back so bad, but can't figure out where to start looking for her..
Last edited by BadBilly442; Aug 7, 2008 at 07:35 PM. Reason: Automerged Doublepost
Old Aug 7, 2008 | 07:43 PM
Re: CAR WON'T START
Just go to the DMV and have them look up the VIN #. It will be under the cars you have owned in the past. Then they can look up where it is now if it is still on the road. They can at least give you the name and address of the last known owner. It is all public information.
Phil
Old Aug 7, 2008 | 08:03 PM
Re: CAR WON'T START
Damn bud thanks for the info, i still have the original Sticker price for the car..the red metallic one..
Old Aug 7, 2008 | 08:15 PM
Re: CAR WON'T START
LAst known owner is here in Camp Verde Arizona i will have to take a ride up there and try and find it..
Old Aug 7, 2008 | 08:17 PM
Re: CAR WON'T START
Good luck. I have had a few cars and trucks I would love to get back but I know I sold them for a reason.
Phil
Old Aug 7, 2008 | 08:30 PM
Re: CAR WON'T START
WOW!!!!!!!!!!!!!!
I am still drooling!So much so that I think I'm gonna drown!!!!!!!!!!!
That car is gorgeous!!I would never sell that!
Anyway,didn't the 91-92 tpi cars have 21lb. inj. and not the prev. year 19lb. ones?That could also cause a problem.
Re: CAR WON'T START
I only sold it because i wanted a new Toyota Tacoma TRD Stepside.. essh what a mistake.. lol.. im gonna try and find this one.. Wish me luck man..
Old Aug 7, 2008 | 08:35 PM
Re: CAR WON'T START
for a TOYOTA???!!!!!WTF! please tell me your kidding.
Old Aug 7, 2008 | 08:39 PM
Re: CAR WON'T START
LOL! yeah don't hate me i got rid of that piece of crap with 8000 miles on the ODO, Ordered a 2003 GT mustang, and i thought the 305's were slow lol.. i got rid of that with 8300 miles on her and Bought a 2000 Ram Air Trans Am.. then a 2003 BMW M3 red on red what a sweet car Fast 6cyl rocket but alas not a V8..
so i got rid of her and im keeping the 91 conv, saving for a 2008 or 09 Z06 Corvette
Old Aug 7, 2008 | 08:48 PM
Re: CAR WON'T START
sounds like a good trade up!If I find that med. red met. vert before you,sorry its NOT FOR SALE! LOL
Old Aug 7, 2008 | 08:54 PM
Re: CAR WON'T START
LOL!! too funny..
Old Aug 8, 2008 | 09:15 PM
Re: CAR WON'T START
yeah,I will never see that car!!Oh my gosh its gorgeous though!
Old Aug 15, 2008 | 08:57 PM
Re: CAR WON'T START
ya find it yet?
Anyway,got the current vert home and running good now?
Keep in mind not to let a car sit in the garage for too long without being run.
You just might find yourself with a bad fuelpump,or worse!
Old Aug 16, 2008 | 02:20 AM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
Re: CAR WON'T START
hey bad billy 442, do you happen to remember what wheels those are? ive been looking for wheels for a long time now and with so many too choose from ive become very picky,but i think youve showed me the ones i want!
Old Dec 6, 2008 | 07:36 PM
Re: CAR WON'T START
ok,I know this thread is old but,just wondering if you ever located that
med. red metallic car BadBilly442
Man do I love that car!
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
